Upgrading Jimny headlights
16 Feb 2026 16:10 #263778 by Landrover
HI
I am wanting to upgrade my headlights However the lens are plastic and not sure about the additional heat from the bulbs are safe on the plastic lens
Any info would be appreciated
16 Feb 2026 18:00 #263783 by facade
Replied by facade on topic Upgrading Jimny headlights
If you want to use it on the road, fit Osram Nightbreakers in place of the standard bulbs.They should be a bit brighter.
They are whiter, so the filaments are hotter, but to quote the late Joe Turkel in Bladerunner "The light that burns twice as bright burns half as long"
Offroad you can just fit a light bar or an array of driving lamps.
There are various non road legal LED conversions, but I'd advise against fitting them.
Don't fit non-road legal "Rally" type bulbs either, they will actually be dimmer as the hair thin wiring can't provide full voltage at their rated current.
16 Feb 2026 18:12 #263784 by Lambert
Replied by Lambert on topic Upgrading Jimny headlights
In my gen3 I currently have ring 200% brighter and they are good and don't seem to be offering any problems. They are however standard wattage and apparently just use some kind of clever gasses instead of normal halogen or so I was told. Running higher wattage is almost certainly going to be a problem with wires and reflector heat management.
16 Feb 2026 18:31 #263787 by facade
Apparently Osram own ring, so the Osram and Ring bulbs are very similar.
Everybody and his dog makes "200%" bulbs.
Here's a review  www.autoexpress.co.uk/exclusive/76760/be...headlight-bulbs-2024
I'm old enough to remember when Ring were the cheapest bulbs you could get, and had the lifespan of a mayfly, now they are a quality brand, like Regatta clothes, which will forever be associated with the cheapest stuff you could buy to me!
16 Feb 2026 18:34 #263788 by fordem
Replied by fordem on topic Upgrading Jimny headlights
Keep an eye on Osram and their LED replacement bulbs. They make an LED replacement that is legal in several countries in Europe, they have been testing in different countries one by one so the list is growing.
16 Feb 2026 19:31 #263791 by Landrover
hi
thanks for the info but do they burn hotter and damage the plastic lens
Time to create page: 0.400 seconds
