Cordless Impact Wrenches 1/2".
05 Feb 2026 10:35 #263626
by fordem
Replied by fordem on topic Cordless Impact Wrenches 1/2".
I think you'll find that the Torque Test Channel shows the Milwaukees (at least the two or three that I have) deliver as promised.
That said, you do need to watch out for "counterfeits", especially where the batteries are concerned.
The following user(s) said Thank You: Roger Fairclough
05 Feb 2026 10:58 #263627
by facade
Replied by facade on topic Cordless Impact Wrenches 1/2".
There are plenty of counterfeit tools about as well as the batteries.
Only buy from a reputable supplier, and make sure that the box has intact factory seals before you accept it, as it isn't unknown for someone to "return" a brand new fake in place of a genuine one, getting a refund and it go back into stock without proper checking.
I've got one of the Lidl Chinese ones, it works well enough for £30, but I wouldn't use it every day.
Apparently you can get nearer the rated torque out of it with a thin washer under the hammer spring to put a bit more tension on it.
05 Feb 2026 11:24 #263628
Replied by mlines on topic Cordless Impact Wrenches 1/2".
Watch this
05 Feb 2026 11:26 - 05 Feb 2026 11:26 #263629
My Startbooster is now two models down from what I bought. approx 30-40 € loss so no bankrupcy but immensly annoying.
Replied by yakuza on topic Cordless Impact Wrenches 1/2".
And check before you leave the store that the item inside the box is the same as you think should be on the inside. Had this problem here at my local "Biltema" kind of like a halfords but in Norway. Open boxes in the shelves and the item inside is the cheaper version. So the guy before me take the expensive model and put it inside the cheaper models packaging.Only buy from a reputable supplier, and make sure that the box has intact factory seals before you accept it, as it isn't unknown for someone to "return" a brand new fake in place of a genuine one, getting a refund and it go back into stock without proper checking.
Last edit: 05 Feb 2026 11:26 by yakuza.
- Roger Fairclough
Topic Author
- Thank you received: 225
05 Feb 2026 13:21 #263633
by Roger Fairclough
Replied by Roger Fairclough on topic Cordless Impact Wrenches 1/2".
Many thanks for all your replies. I have ordered a Milwaukee unit from Toolstation which is slightly more powerful than my Axminster pneumatic and that had twice the power of a standard run of the mill wrench that most dealers sell, so my wheel nuts will quiver with horror when they see it!
Roger
Roger
- Thank you received: 1999
05 Feb 2026 17:14 #263635
Replied by Lambert on topic Cordless Impact Wrenches 1/2".
If you have locking wheel nuts do them by hand. Impacts will kill them especially some of the heavy hitting ones on full power.
Time to create page: 1.151 seconds
