Noco genius 2
- Thank you received: 2005
30 Jan 2026 07:29 #263581
Noco genius 2 was created by Lambert
Looking for a maintenance charger well one each for temeraire and leviathan actually, they aren't getting much regular use so want to avoid battery damage and no starts. If not the noco genius 2 then a suitable alternative?
The following user(s) said Thank You: CelicaRacer
- CelicaRacer
- Senior Member
- Thank you received: 15
30 Jan 2026 07:45 #263582
by CelicaRacer
1999 Suzuki Jimny
1990 Toyota Celica garage queen
1996 BMW e36 touring track car
2007 BMW e61 520d touring
1998 BMW Z3 Drift Car
Replied by CelicaRacer on topic Noco genius 2
I have not had any experience with the noco trickle charger but plenty with their jump packs and I swear by them, very good and compact.
I got a battery charger but a very cheap one I got off lidl or aldi and it does work..
1999 Suzuki Jimny
30 Jan 2026 09:07 #263583
by Brian J
Replied by Brian J on topic Noco genius 2
I am a long-term user of Optimate chargers for my motorbike and car. I have always found them both effective and reliable.
- Thank you received: 677
30 Jan 2026 09:08 #263584
Replied by DrRobin on topic Noco genius 2
I have a CTEK MXS 5.0, had it a good few years now and it’s been great, although they are a bit more expensive than a Noco, I assume.
CTEK pulse charge whilst monitoring the battery so they can’t over charge and when full go in to trickle charge or even (I think) cycling the battery (recondition), but I have never used it as a trickle charger.
In addition to the usual croc clips they come with a plug and socket and you wire the socket in under the bonnet, then it’s easy to plug and unplug the charger without fear of shorting, even with the bonnet down.
I have the socket wired in to my other car as it needs regular charging.
Robin
Robin
30 Jan 2026 09:23 #263585
Replied by Soeley on topic Noco genius 2
I also have an Optimate, from my Maxi-Scooter days, very good. It does trickle/maintenance charge and battery conditioning. Designed to be plugged in and forgot about basically. It also has a connector you can permenantly connect so it's a case of plug it in rather than clip it on.
30 Jan 2026 09:28 #263586
by jlines
1986 SJ413JX (Lil Red)
2018 JB43 SZ4
2019 JB74 SZ5 (Gerald)
2023 JB74 LCV
Replied by jlines on topic Noco genius 2
I've got the basic CTEKS for BigJimny, my SZ5 and the SJ. Just plug them in and leave. As you know my SJ, SZ5 and even BigJimny sit all winter and I haven't had any battery issues.
2018 JB43 SZ4
2023 JB74 LCV
Time to create page: 0.182 seconds
