Throttle Position Sensor
18 Nov 2025 17:40 #262806
Replied by jackonlyjack on topic Throttle Position Sensor
I found it in Ai search on Google
You set closed voltage and wide open voltage
Never tried it myself
18 Nov 2025 22:47 #262814
by chris
Replied by chris on topic Throttle Position Sensor
From other issues ive had with this jimny and from what ive read back in this forum, i have convinved myself that the cat converter is blocked. if i try disconnecting the exhaust through the clamp just below the engine, should this fix my problem and tell me that i need new cats? ive ordered yet another tps sensor and will put that in tomorrow to see if that changes anything. About calibrating the tps i read somewhere on the forum that martin said it learn itself but can seem to take forever to learn, so maybe that will happen. Thanks for all the responces and id appreciate any further advice
19 Nov 2025 11:12 #262829
by chris
i took the exhaust off at the joiner shown in the picture just after the manifold. the engine was LOUD but it was finally able to rev past 3000. on my 2008 M13A is there a cat behind that heat shield? what part of the exhaust would i likely have to repair to fix this problem?
thanks
thanks
19 Nov 2025 15:23 #262837
The cat behind the heat shield can be smashed out and removed without causing any issues
It's possibly already started to disintegrate and blocked the exhaust cat resulting in your issue
Probably going to have to replace the 2nd cat
The following user(s) said Thank You: chris
19 Nov 2025 22:29 #262844
by chris
yes youre completely right. i took the section of exhaust off and the entire manifold cat had disintegrated and was clogging the second cat. big chunks just stuck in the pipe. ive removed both cats for now and the difference is night and day. will get a new second cat on asap. i have recieved the new throttle position sensor from the motorfactors, 80euro!... so ill stick that in tomorrow and see if that keeps the CEL away! i have high hopes for this jimny so hopefully everything works out. i will hopefully be back with more good news tomorow! thank you everyone
20 Nov 2025 07:43 #262845
Y not try the TPS you had on and send the new one back for refund
