31" tyres on a Gen 4
17 Nov 2025 13:07 - 17 Nov 2025 13:32 #262781
by saxj
31" tyres on a Gen 4 was created by saxj
I've had 235/75R15's on for around 100000Km now, and it's time to change tyres.
I'm considering 31" tyres.
I have reduction gears in the t-case, so gearing is not an issue.
I have a 50mm lift, front radial arms are 15mm longer and aftermarket bumpers that give plenty of clearance for bigger tyres.
Besides possibly extending bump stops, is there anything else I need to consider?
Has anyone experienced driveline breakages with 31" tyres?
Last edit: 17 Nov 2025 13:32 by saxj. Reason: Not clear
17 Nov 2025 13:26 - 17 Nov 2025 13:27 #262782
by 300bhpton
Replied by 300bhpton on topic 31" tyres on a Gen 4
235's.... 235/85R16? Or do you mean a 15" size?
JimnyBits have 31.10.50R15's on their website:
www.jimnybits.com/jimny-19-on/suspension...nsion-lift-kits.html
But that is on a 4" lift, so it runs extended bump stops to prevent the wheel moving up as far into the arch, along with longer shocks to give more total droop and travel.
I guess rim offset will also play a factor on how close or if they rub anything under steering or flex.
Interesting to see how you get on.
Last edit: 17 Nov 2025 13:27 by 300bhpton.
17 Nov 2025 13:39 #262783
by saxj
Replied by saxj on topic 31" tyres on a Gen 4
The current tyres are 235/75R15's. I intend running the new tyres on the stock rims.
17 Nov 2025 15:40 #262784
by 300bhpton
Certainly not saying don't do it. But probably worth noting that the rim range for a 31.10.50R15 is 7-9". So the stock 5.5" rim is well under spec.The current tyres are 235/75R15's. I intend running the new tyres on the stock rims.
19 Nov 2025 14:54 #262833
by saxj
I'm not too fussed about the rim width. I have a friend who runs 31's on the stock rims, but on an SJ.
19 Nov 2025 15:04 #262834
by jlines
1986 SJ413JX (Lil Red)
2018 JB43 SZ4
2019 JB74 SZ5 (Gerald)
2023 JB74 LCV
Replied by jlines on topic 31" tyres on a Gen 4
With running those sorts of tires you can expect more breakages from wheel bearings, CV joints and even diffs even more so if you are offroading the car. The stock axles on a Jimny aren't that strong so once you go over 30s you are starting to strain them especially if pushing hard offroad.
2018 JB43 SZ4
2023 JB74 LCV
Time to create page: 0.209 seconds
