Kill switch
20 Sep 2025 11:36 #262028
by fordem
Replied by fordem on topic Kill switch
Relay or no relay, you can disable the fuel pump by interrupting the power supply to the fuel pump literally anywhere in the circuit.
As I said before, doing it with a fuse tap is the easiest way, which also makes it the easiest way to reverse the modification and that makes it the easiest way to bypass the kill switch, if a thief were to notice it.
Personally, I wouldn't fit a kill switch - simply because for it to be effective, I would need to flip the switch every time I park and then flip it again when I get back to the car. Sooner or later, sooner, rather than later, I'll get tired and stop doing it.
IF I were to fit a kill switch, I would want it within easy reach of the driver, if it's on the dash it would need to be concealed, or perhaps disguised, let's say, a fog lamp switch that matches the dash switches, and the wiring can then be concealed under the dash and run to where ever you choose to interrupt the circuit.
The following user(s) said Thank You: Filipao
- danparry 91
21 Sep 2025 00:17 #262032
by danparry 91
Replied by danparry 91 on topic Kill switch
Is there a Relay fuse tap available??
Obviously there's a mini fuse tap which i have.
If not I won't worry with the jimny as i don't really want to cut factory wiring
21 Sep 2025 17:15 #262041
by fordem
Quite frankly - I would not worry with a Kill switch on a Jimny that does not have keyless start, it already has a fairly effective immobilizer.
It's not that the immobilizer can't be bypassed, but it's not as easy as it would be on your Lexus, I'd also like to think that a Lexus (or a Mercedes) would be considered a much more desirable target than a Jimny.
21 Sep 2025 18:37 #262042
Replied by jackonlyjack on topic Kill switch
I have after market alarm
Pedal lock and Kryptonite wire with padlock
Hopefully this makes them move on and find an easier target
22 Sep 2025 01:39 #262045
by Filipao
Replied by Filipao on topic Kill switch
Christ, where are you guys located...?
22 Sep 2025 06:51 #262046
by Hughes
Replied by Hughes on topic Kill switch
Now that I think about it, the fuel pump is fed off one of the primary fusible links, not a mini fuse in the box.
So yeah, cutting into the factory wiring is the easiest way.
Not impossible, but does add another failure point.
I also would probably be inclined to only use it if parked in rough areas, (rare for me) as having to fumble for a secret switch under the dash would get old pretty quick for me.
Time to create page: 0.188 seconds
