Help - yellow liquid from middle bracket of exhaust?
30 Mar 2025 10:50 #259977
Replied by jackonlyjack on topic Help - yellow liquid from middle bracket of exhaust?
Mine drips water from said joint always has I put it down to condensation in the exhaust
But mines clear
Maybe someone has tried to wash the catalytic converter out with something......
But mines clear
The topic has been locked.
30 Mar 2025 12:52 #259979
by facade
Replied by facade on topic Help - yellow liquid from middle bracket of exhaust?
I still think it will be dripping from above, however-
assuming that it is coolant, how are you checking that the level isn't going down?
Have you checked the radiator when cold?- it should be full right to the tippy top under the cap, or are you just looking at the expansion bottle?
If there is a leak in the system it won't draw coolant back from the expansion bottle.
The level in the expansion bottle should go up significantly when hot, and then drop back to normal when cold.
30 Mar 2025 18:02 #259981
by Simonp
Replied by Simonp on topic Help - yellow liquid from middle bracket of exhaust?
Hi thanks. Ok I attach a photo of expansion bottle (normal), radiator (full to brim) and bracket where the drip is coming from. I have also taken a photo directly above the bracket - everything is completely dry! Hence the mystery…..
30 Mar 2025 18:29 #259982
It seems where at the point of random guesses
Have you used a fuel additive, removed throttle body and looked in the Inlet
Is air filter deteriorated and pulling partials through
It's a start
It's a start
30 Mar 2025 18:50 #259984
by Simonp
Thanks! Looks like a referral to a garage and to set out some of these suggestions. Much appreciated
03 Apr 2025 19:30 #260014
by Simonp
Hi. Update is that tonight I found the same liquid directly underneath the radiator- not much, but a drop all the same (see photos). I have taken one photo from the top of the engine bay and you can make out the green liquid on the floor just beyond the radiator . What does this mean? Question is how a leaking radiator is leaving coolant in the exhaust..? I’m not sure that is good news at all? Any advice appreciated!
