engine change
- AllanBartlett177@gmail.com
25 Feb 2025 22:42 #259590
by AllanBartlett177@gmail.com
engine change was created by AllanBartlett177@gmail.com
hi all has anyone fitted M13a engine from suzuki swift into suzuki jimny if so are there any major differculties
25 Feb 2025 23:02 #259591
by fordem
Replied by fordem on topic engine change
What engine did the Jimny originally have, and is the Swift engine VVT?
26 Feb 2025 07:19 #259592
Replied by AllanBartlett177@gmail.com on topic engine change
the jimny has a M13a in it. I dont have a swift engine at the moment but there are alot more swift engines available is there a particular swift model that will fit the jimny
26 Feb 2025 11:24 - 26 Feb 2025 11:27 #259593
Replied by yakuza on topic engine change
As Fordem says you need to fint out if your car is a VVT or not. And use the same from the Swift.
Usually your engine is a VVT from 2005 and later.
There are differences between markets and models I may not be aware of but the engine longblock should fit.
The basic engine from the donor swift, and all the outside parts from your existing engine like generator, starter, intake, exhaust, pipes and hoses, electrical and so on.
Last edit: 26 Feb 2025 11:27 by yakuza.
27 Feb 2025 08:46 #259606
thankyou I will check my engine hopefully it will be vvt cheers Allan
27 Feb 2025 12:54 #259610
Oh there is no problem if it isnt, there are most likely Swift non VVT too available.
My Swift 4x4 2007 is a non VVT.
