Wheel balancing - Centre (hub) or stud
01 May 2025 19:38 #260279
by facade
Replied by facade on topic Wheel balancing - Centre (hub) or stud
Not that I'm aware of.
We are split into two camps
Those of us who are practical engineers insist that the tapered nuts, and the fact that the wheels don't jam on solid with alloy corrosion means that they are stud centric and the hub ring doesn't touch the wheel. The steel wheels should be stud centric as the centre hole clears the ring on the hub
Those of us who are used to modern alloys that you have to either beat off the car with hammers or slacken the nuts and roll backwards & forwards stamping on the brakes until they come loose insist that they are hub centric- they must be if they are jammed on the hub rings..... (My electrocar had all 4 wheels jammed on solid when I got it, and had to have them "persuaded" off, yet it has tapered bolts)
As far as I can tell, when Suzuki finished the alloy wheels, they machined the centre hole & flange concentric with the nut tapers (It is no more trouble to set the machine up to do the job properly than to set it up wrong.... plus there will be unnecessary strain if the wheel locates by the hub and then the stud tapers are way out when you tighten them up ), so it doesn't really matter which way you balance them!
The following user(s) said Thank You: Darthblaker7474
02 May 2025 01:56 - 02 May 2025 01:57 #260286
by fordem
Replied by fordem on topic Wheel balancing - Centre (hub) or stud
If the lug/bolt holes have a tapered seat, the wheels are "lug centric", if the lug/bolt holes have a flat seat, the wheel is "hub centric" - if you've ever fitted a "hub centric" wheel to a vehicle, you'll know that there is no disputing this.
When it comes to balancing, it doesn't make a difference, because the center bore is going to be concentric with the wheel rim. Most wheel balancers use a cone to center the wheel on the spindle so they can accommodate wheels with different sized center bores.
Last edit: 02 May 2025 01:57 by fordem. Reason: reword for clarity
02 May 2025 06:23 #260289
by Motacilla
In olden times, when machining was done by men in brown coats, it probably mattered more.
Replied by Motacilla on topic Wheel balancing - Centre (hub) or stud
See @facade's note above. Particularly with alloys, the machining will all be concentric anyway, so the practical effects of hub vs stud balancing are nil.Did we ever get a definitive answer for this?
Time to create page: 0.316 seconds
