Rear brakes conversion Gen4
19 Feb 2024 18:51 #254449
by Plod64
Rear brakes conversion Gen4 was created by Plod64
I have replaced the front brakes on my Jimny with Endless Brakes. I am still investigating a rear drum to disc conversion.
I am not a technical man and wish to do the conversion using.Endless.
Can any members suggest which calipers and discs which Endless supply suitable for this job.
kind regards Mark
kind regards Mark
- Thank you received: 679
19 Feb 2024 19:03 #254450
Replied by DrRobin on topic Rear brakes conversion Gen4
You would probably be better off asking Endless.
19 Feb 2024 21:43 #254455
by lightning
Replied by lightning on topic Rear brakes conversion Gen4
What would be the advantage of fitting rear discs to a Jimny.
19 Feb 2024 22:30 #254456
by Busta
Replied by Busta on topic Rear brakes conversion Gen4
It's a common modification on earlier Jimnys, and I suspect the parts needed will be the same. I've never heard of endless but there are several companies that make conversation kits.
Advantages of discs on the rear are better performance in muddy and wet conditions and easier wheel bearing changes. It's fairly common for the drums to fill up with mud which renders then useless and wears out the shoes quickly.
- Roger Fairclough
- Thank you received: 225
19 Feb 2024 22:36 #254457
by Roger Fairclough
Replied by Roger Fairclough on topic Rear brakes conversion Gen4
The standard drum brakes will quickly fill with mud if you enjoy "mud plugging" and the mud will dry and basically wreck the whole rear braking system. On my SJ ( series 2 ) and the LC I would strip and clean after every trip that had involved deep wading in liquid goo.
Fitting a disc brake conversion pretty much remedies this situation although you will need to clean the system but care needs to be taken if you use a pressure washer. When I came back from a trip I would visit Coughton ford for a few trips through as this would wash off most of the mud.
The other consideration is the seal on the half shaft bearing. This seal is designed to keep the grease in, it is useless at keeping water out. I made up a secondary seal system using a proprietary 2RS ( 2 rubber seals ) and that solved the problem.
Roger
Roger
19 Feb 2024 22:37 #254458
Endless big brake kit, not cheap, about £2,300 to £2,600 depending on the discs and pads, they only appear to make them for the front.
streettracklife.com/products/endless-big...or-suzuki-jimny-2018
Time to create page: 0.111 seconds
