Rear brakes conversion Gen4
19 Feb 2024 23:06 #254461
by 300bhpton
Replied by 300bhpton on topic Rear brakes conversion Gen4
That is an insane amount of money for Jimny brakes, I personally cannot fathom why you'd fit them.Endless big brake kit, not cheap, about £2,300 to £2,600 depending on the discs and pads, they only appear to make them for the front.
streettracklife.com/products/endless-big...or-suzuki-jimny-2018
- Roger Fairclough
- Thank you received: 225
20 Feb 2024 09:58 #254473
by Roger Fairclough
Replied by Roger Fairclough on topic Rear brakes conversion Gen4
And you still finish up with an old style solid - not vented - disc. Plus connecting the hydraulics on the caliper with a short length of pipe is odd and a poor engineering concept as apposed to the simpler and better idea of internal passages and an "O" ring.
Roger
Roger
- Thank you received: 2001
20 Feb 2024 10:11 #254474
Replied by Lambert on topic Rear brakes conversion Gen4
Not really, I was looking at something similar when I was track daying my last jimny, for that kind of thing standard plus just won't cut it, I'd be getting fade after just one session.
- rogerzilla
20 Feb 2024 19:55 #254488
by rogerzilla
Replied by rogerzilla on topic Rear brakes conversion Gen4
I know there is a Jimny in Gran Turismo now (660cc turbo kei version) but I didn't think anyone actually did track days in them!
20 Feb 2024 20:59 - 20 Feb 2024 21:03 #254491
Replied by yakuza on topic Rear brakes conversion Gen4
I know i might not be your average jimny offroader. But I have had more disc brake than drum brake problems. I swap the internals of my drum brakes once a year or before the mot.
Open and inspect and twice a year.
I have had gravel, pebbels and sticks stuck in the calipers, broken seals making them rust so pistons stick, discs getting warped, discs rust, brake pads disintegrate and all this while the rear drums just work.
Brakes are the same on gen 3 and gen 4 right?
Vented discs and front caliper kit can be bought here. Recommended!
Last edit: 20 Feb 2024 21:03 by yakuza.
- rogerzilla
21 Feb 2024 07:42 #254496
by rogerzilla
Drum brakes are coming back on EVs.
EVs don't use the physical brakes much (because of regen) so they don't need particularly effective rear brakes. Drums are cheaper, need less servicing, and don't get pitted from lack of use. You get an easier and generally better handbrake arrangement with drums. There is also less drag when the brakes are off.
Time to create page: 0.193 seconds
