Oil filter removal.
16 Feb 2024 20:11 #254384 by grumyoldjoe
Replied by grumyoldjoe on topic Oil filter removal.
Wine improves with age.
17 Feb 2024 06:20 #254391 by Doctorchris
Replied by Doctorchris on topic Oil filter removal.
I use a strap wrench that fits onto a socket wrench. I use it because that's what I have had in my toolkit for ages. It works but it is rather awkward, especially taking up the tension in the strap. If I was buying a new device specifically for the Gen4 Jimny I would choose something else.
17 Feb 2024 09:24 #254394 by Roger Fairclough
Many thanks for all your responses. The Gen.4 oil filter is approx. 63mm in diameter which is right at the bottom end of the usual " fits filters between 62-120mm in diameter" so yes, there is a problem of excess slack in chain or strap. I made my chain wrench to suit the very large filter on my LC and so had the fiddly problem of getting it onto the Jimny's filter and then holding it into position whilst lying on my back. Not easy! I intend to visit Toolstation and look at a Draper fabric wrench and consider if shortening the strap material would make it easier to use.
Roger
19 Feb 2024 17:24 #254447 by Roger Fairclough
It's warmer and drier so I got underneath to measure the gap between filter and sump. Answer is approx. 10 mm ( gap actually tapers but 10 mm is close enough). I measured my chain wrench ( std. bike chain ) and decided a bit of grinding would suffice and bingo, it fits nicely, so problem solved ( hopefully, it will be 12 months before I try it out ).
Roger
  • rogerzilla
19 Feb 2024 17:41 #254448 by rogerzilla
Replied by rogerzilla on topic Oil filter removal.
You could use the time-honoured, if messy, method of banging a big screwdriver right through it.
19 Feb 2024 20:11 #254452 by Busta
Replied by Busta on topic Oil filter removal.
Banging a screwdriver through is the worst thing you can do! If the filter is tight it just peels the filter open like a can opener, then you are left with a mangled, jagged, dripping mess to remove.
If you're smart enough to oil the o-ring and not over-tighten the new filter it should only be hand tight when the time comes to change it. But most people can't resist over tightening them.
Time to create page: 0.217 seconds
