Oil filter removal.
- Roger Fairclough
Topic Author
- Thank you received: 225
19 Feb 2024 20:35 #254454
by Roger Fairclough
Replied by Roger Fairclough on topic Oil filter removal.
I agree.
Roger
Roger
- rogerzilla
24 Feb 2024 10:53 - 24 Feb 2024 10:55 #254541
by rogerzilla
Replied by rogerzilla on topic Oil filter removal.
I changed the oil on the gen3 this morning. I put the old filter on by hand in August (she does short trips in it, so 6-monthly changes) and it came off by hand, as it should. It's only usually when a garage has put the filter on that you get problems. I assume they use a tool for tightening, which is not what any handbook will tell you to do.
It is my favourite car to do an oil change - such easy access. The only downside is that you always spill oil down the engine block when removing the old filter. I stuff rags underneath beforehand but some always gets past.
Last edit: 24 Feb 2024 10:55 by rogerzilla.
- Roger Fairclough
Topic Author
24 Feb 2024 13:26 #254543
by Roger Fairclough
Normally I would agree that tightening the filter by use of a tool is unnecessary, but the official Toyota repair manual for the 1KZ-T engine says.
"Tighten the filter by hand until the rubber gasket contacts the seat of the filter housing and then using SST ( as mentioned by Lambert earlier) give it an additional 3/4 turn to seat the filter"
Yes, it's ambiguous. I find that hand pressure has always worked for me and so it will remain.
Roger
Roger
- Roger Fairclough
Topic Author
24 Feb 2024 13:41 #254544
by Roger Fairclough
I've just had a look at the Suzuki manual and that says:-
Either tighten filter to 10.5 lbs-ft
or
Tighten by hand and then add 3/4 turn by wrench.
Roger
or
Roger
- rogerzilla
24 Feb 2024 14:10 #254545
by rogerzilla
That's probably a mistranslation. All spin-on oil filters work the sane way, and it's 3/4 turn from when the O-ring makes contact, not 3/4 turn after hand tight.
- Roger Fairclough
Topic Author
24 Feb 2024 16:23 #254547
by Roger Fairclough
Yes, missed out "until O ring makes contact with seat and then add 3/4 turn."
Roger
Roger
Time to create page: 0.196 seconds
