Virgin Jimny owner - be gentle.
13 Feb 2024 20:12 - 13 Feb 2024 20:14 #254270
by Scimike
Replied by Scimike on topic Virgin Jimny owner - be gentle.
Hi and Welcome.
RE central locking - if a new battery doesn't help try cleaning the buttons.
Ours stoped working, it was dirt in the surface mount buttons. Remove the PCB and soak the two buttons in contact cleaner, work them repeatedly unit they start to "click". Let it dry and do it again! Note a quick spray with cleaner will do nothing, you do need to press the buttons when submerged in cleaner.
Took three cleans to get ours working, but been fine since.
Worth a try.
Worth a try.
Last edit: 13 Feb 2024 20:14 by Scimike.
The following user(s) said Thank You: Jamento
- Thank you received: 673
13 Feb 2024 20:29 #254275
Replied by DrRobin on topic Virgin Jimny owner - be gentle.
Scimike should have plugged Halfords Electrical Contact Cleaner, it's very competitively priced and in my opinion excellent as it evaporates and leaves no residue unlike something like WD40, which leaves an oily film.
I first used it as a Carb/intake cleaner, even used it to clean my MAF sensor on my other vehicle, electrical contacts (of course) and really good at getting grime off plastics or precious metals (like a watch for example).
Since it leaves no residue it is generally safe for most electronics, some sprays will track up the side of semiconductors (ICs or Chips) and destroy the internals, but this seems safe.
I haven't been to the IoW since the late 80s, I had two windsurfing trips there staying on the south west of the island, loved it.
Robin
Robin
- Jamento
16 Feb 2024 20:23 - 16 Feb 2024 20:23 #254385
by Jamento
Replied by Jamento on topic Virgin Jimny owner - be gentle.
Just catching up. You've all been so very helpful and I just wanted to say thanks.
What a palaver getting a CR1616 battery. For some reason no Amazon battery sellers would ship to the island. Mental.
Hopefully when I try it tomorrow it will work, if not I'll try the deep clean mentioned and if the worst happens, fit an el cheapo one from ebay.
I can't find a replacement wing mirror that doesn't need spraying so can anyone recommend a good place to get a can of spray for suzuki? Guessing the mirror comes primed.
Last edit: 16 Feb 2024 20:23 by Jamento.
- rogerzilla
16 Feb 2024 21:04 #254386
by rogerzilla
Replied by rogerzilla on topic Virgin Jimny owner - be gentle.
I got some bluish black metallic from eBay and it was a very good match. A slight mismatch would be less noticeable on a mirror - I had to do a corner of the roof and part of the tailgate.
- Jamento
21 Feb 2024 21:21 #254504
by Jamento
Thought I'd give this a go before I try Robin's advice and get rogered by the Suzuki dealer.
You're referring to a suzuki standard CL key fob right?If you can't get the CL working, then you can fit a £10 Chineesium one off Fleecebay
- rogerzilla
22 Feb 2024 06:44 - 22 Feb 2024 06:45 #254505
by rogerzilla
The key has three elements:
1. The physical key blade, needed to turn the ignition barrel and the door locks
2. The immobiliser chip, built into the plastic body of he key. Without this, the ignition barrel will turn but the car won't start
3. The central locking "pod" inside the key, which is removed to change the battery.
Most locksmiths can cut a new (1) and an aftermarket (3) can usully be coded to the car using a particular sequence. However, an afternarket (2) cannot be coded to the car by the user. It has to be cloned from a working immobiliser key.
Basically, don't buy a whole key if only the remote CL isn't working. Just get the internal pod with battery.
Last edit: 22 Feb 2024 06:45 by rogerzilla.
