Virgin Jimny owner - be gentle.
- Jamento
11 Feb 2024 22:39 - 11 Feb 2024 23:20 #254235
by Jamento
Virgin Jimny owner - be gentle. was created by Jamento
The wife has always wanted a Jimny but where we live (IoW) they're like hens teeth. After waiting an age, one came up last week. Private seller, 2008, 75k with only 2 owners and lots of service history. Got a pretty sweet deal too based on AT prices.
I know next to nothing about Jimny's or cars for that matter and it's got a few issues (mentioned below), but overall we're very happy with it.
Logbook only has VVT noted so I assume it's a Gen 3, JLX VVT 1.3
1. Previous owner (really old fella) says it doesn't have central locking, but it came with 2 keys and one is a fob. Maybe the battery just needs changing?
2. Steering judders at 45mph (balance/kingpins/bush according to a search on this site). Is this an expensive repair?
3. Full beam intermittent on dash and one of the rear number plate bulbs isn't working and the fella said it's "more" than just changing the bulb.
4. Fading/bleached paint work on bonnet. Hopefully it can be polished out instead of needing re-spray.
5. Where can I buy a hard copy owners manual?
6. No paperwork for timing chain replacement, so is this something that can be checked or should I just replace it? Is it a cheap or expensive job?
7. Drivers electric wing mirror needs replacing. Is that an easy job for a muppet?
8. £320 for road tax
9. The Jimny was pretty gutless when going up a sustained hill. I know it's only a 1.3 and it was steep, but maybe there's a minor problem there too.
If anyone has any advice or tips on the (too many questions, sorry) above it would be very much appreciated. Thanks.
Great little piece of kit overall. Can see why they have such heritage now and hold their prices really well.
Last edit: 11 Feb 2024 23:20 by Jamento.
11 Feb 2024 23:38 - 11 Feb 2024 23:40 #254236
Replied by yakuza on topic Virgin Jimny owner - be gentle.
Welcome to the forum!
1. My prev owner was 95
2. Do kingpin first. Make sure the chosen garage know how to.
6. It is a chain so need no service like the ones with a belt. so no worries, will last the life of the engine.
9. They are not fast. Dont be afraid to use the rpm and a heavy foot, they can take the abuse.
Last edit: 11 Feb 2024 23:40 by yakuza.
The following user(s) said Thank You: Filipao
12 Feb 2024 06:36 #254238
by gv42
Replied by gv42 on topic Virgin Jimny owner - be gentle.
A Jimny welcome
The following user(s) said Thank You: Jamento
- Jamento
12 Feb 2024 10:39 - 12 Feb 2024 11:09 #254240
by Jamento
Replied by Jamento on topic Virgin Jimny owner - be gentle.
He wasn't quite 95, but he was getting there!
Thanks for the tips and duly noted regarding the garage/kingpins and the heavy foot/rpm.
This site is brilliant for help and tips. I had no idea about when/how to use the 4wd and have to drive defensively.
I would really like the get the central locking query resolved if anyone knows??? Why would it come with a fob if it's not CL?
Good to know about the timing chain too. I had read it had to be changed between 80-100k. So much conflicting info out there.
Last edit: 12 Feb 2024 11:09 by Jamento.
- rogerzilla
12 Feb 2024 11:07 - 12 Feb 2024 11:08 #254241
by rogerzilla
Replied by rogerzilla on topic Virgin Jimny owner - be gentle.
The key buttons should work. If not, see if the screw head has been stripped by a hamfisted previous attempt to change the battery. I had to drill the head off (after getting a new screw). The battery is CR1616 or CR1620. They both fit - CR1620 is marginally thicker - but often one works and one doesn't. Buy whatever is in there already.
Last edit: 12 Feb 2024 11:08 by rogerzilla.
12 Feb 2024 11:10 #254242
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Replied by me101 on topic Virgin Jimny owner - be gentle.
Hi, you get used to the lack of grunt! Does the locking work on the key (when the key is used in the door rather than remote)? If not, changing the key battery will have no effect. If number plate bulb does not work with a new bulb, just take a new feed from the one next to it. Only use 4wd when off tarmac (or ice / snow)
Cheers
Cheers
