Front Brakes
- Thank you received: 679
18 Oct 2023 12:40 #251543
Front Brakes was created by DrRobin
Although my Gen 3 sailed through it's MOT last week the garage mentioned that the front discs have slight scoring on them and they will need to be changed before the next MOT. Since we are going in to Winter I might as well do them now and I am not fitting new discs without new pads.
After reading on here that EBC Greenstuff pads are the ones to go for I am now wondering what I should use for the discs? I always used Brembo or Pagid on my other car, but all discs seem to wear quickly these days so is it worth paying extra for the disc?
Anyone got a recommendation? My discs are the standard type with the 108.3mm centre hole.
Robin
Robin
18 Oct 2023 13:02 - 18 Oct 2023 13:03 #251546
by Busta
Replied by Busta on topic Front Brakes
How bad are we talking? Slight scoring is not a reason for MOT failure. It's not really an issue at all. If the disc is above the minimum wear thickness then I wouldn't rush to change them.
From the MOT inspection manual:
1.1.14. Brake discs and drums
A brake disc or drum must be significantly worn before you should reject it. Being worn below the manufacturer’s recommended limits is not a reason in itself.
Defect
(a) Brake disc or drum:
(i) significantly and obviously worn
(ii) insecure, fractured or otherwise likely to fail. Major, Dangerous
(b) Contaminated with oil, grease etc. Major
(c) Missing. Dangerous
(d) Brake drum back plate insecure. Major
Defect
Last edit: 18 Oct 2023 13:03 by Busta.
18 Oct 2023 13:08 #251547
by gv42
Replied by gv42 on topic Front Brakes
I got the EBC green stuff pads and the EBC disc , on my 3 jimnys very good
18 Oct 2023 13:30 #251548
Replied by DrRobin on topic Front Brakes
I haven't seen the discs, but the local garage (who I have delt with for many years and trust) said there was scoring which would need to be fixed before the next MOT. I assume that means they don't think they will pass next October, so no real rush.
I had thought about Greenstuff pads for a while and since the braking force is not quite as good as it was a year or so ago it's time for new pads. For the cost of a pair of discs I might as well change them at the same time.
Thanks for the EBC recommendation.
- Thank you received: 2006
18 Oct 2023 15:11 #251553
Replied by Lambert on topic Front Brakes
Ebc disc and pad combo here too. You will wonder how you ever managed to avoid hitting anything once you change.
18 Oct 2023 15:19 #251555
Thanks.
I think I am going to go EBC discs and Greenstuff pads, it's a few hours to swap them over and I don't want to fit something that then needs doing again fairly soon.
I have seen the kit for about £90, not too bad. I am not going to do it this weekend it looks fairly wet up here.
Robin
Robin
Time to create page: 0.477 seconds
