rear axle
07 Apr 2023 16:10 - 07 Apr 2023 16:14 #248425
by mag
Hi all , this is going to sound dumb !!
standard 04 jimny , no lift , the rear drivers side appears to sit 3cm lower than passenger side ( measured from bottom of wheel arch lip )
and the right hand rear wheel appears to have moved a few cm to the left ! top of the wheel appears to be further in than the bottom.
Nothing obvious appears broken , snapped or bent , any ideas what to look at in greater detail
Drives fine by the way !!
Last edit: 07 Apr 2023 16:14 by mag.
07 Apr 2023 17:53 #248428
by Scimike
If you can jack the body up so that it lifts the vehicle and extends the rear suspension. This involves jacking from the bodywork/ chassis, so please be careful if you get underneath. Once it's lifted have a good look at each spring and axle / body mounts for damage. Check the spring ends for missing coils or cracks etc.
ITS possible the Jimny has a natural lean, but ours is perfectly level so not sure why some report this. So my suggestion is based on looking for damage rather than if a lean is correct or not.
The following user(s) said Thank You: mag
- Thank you received: 2004
07 Apr 2023 19:08 #248429
Tend to agree with the above, 30mm is a lot for there not to be a snapped coil spring.
- Thank you received: 706
08 Apr 2023 08:43 #248433
Replied by jackonlyjack on topic rear axle
Does it have the standard pan hard rod ?
check the upper spring mounting points
also pan hard mounting point at chassis end and the U channel diagonal from
pan hard up to chassis cross member
Time to create page: 0.077 seconds
