Alternator
- Donovan
09 Jan 2023 11:50 #246773
by Donovan
Alternator was created by Donovan
Hi there,
a quick backstory, I have been on leave and haven’t started my Jimny for about 7 weeks. Came back and battery flat. Ran the good old jumpers and it fired up. After about a minute there was a wonderful crackling and a lovely Smokey aroma coming from in and around the alternator. The little engine then died a sudden death. It would not turn over again, not even a little solenoid click. Checked ignition fuse and that’s blown. The fuse contacts are stuck in the fuse box so I will need to figure that out later. Does this sound like a burnt out alternator, and if so does anybody in the Hampshire region have one for sale for a W Reg Jimny. Any help would be awesome.
thanks kindly
Donovan
thanks kindly
Donovan
- Thank you received: 2004
09 Jan 2023 12:41 #246775
Replied by Lambert on topic Alternator
Sounds like the alternator is going to be a good place to start looking that and the associated wiring. Don't know of any reconditioning places but there's going to be somewhere that can.
- Donovan
09 Jan 2023 12:44 #246776
by Donovan
Replied by Donovan on topic Alternator
Thanks a lot for the reply. Going to remove it today and see what’s about. Appreciate it.
10 Jan 2023 19:28 - 10 Jan 2023 19:29 #246806
by Scimike
Replied by Scimike on topic Alternator
If cash is tight and secondhand scarce try find a local auto electric repair shop. I've had my Land Rover alternator tested and repaired for about £25 locally.
I would also put emphasis on checking the wiring associated with the charging circuit as mentioned by Lambert. The stuck and blown fuse may indicate possible heat damage to the cable insulation caused by the high current. Check it over before you reconnect anything.
Of course don't forget your flat battery, try to charge it and get it tested (for free) at any Halfords. No association (now), just aware they have Yuasa battery testers that can work on/off the vehicle and it's a free service if you ask.
Last edit: 10 Jan 2023 19:29 by Scimike.
- Donovan
10 Jan 2023 22:47 #246816
by Donovan
Thanks for the info, I will check the circuitry over tomorrow. Appreciate the help
Time to create page: 0.084 seconds
