problems by starting up
09 Nov 2022 12:13 #245842
by dave55555
Replied by dave55555 on topic problems by starting up
Hi Lambert, no it s just i am used to my wagon r, which after a key turn fired up at once.. it takes normally 2or 3 sec to start. Yesterday it didn t fire up till the second attemp (first did not start at all)
09 Nov 2022 12:55 - 09 Nov 2022 12:57 #245844
by Scimike
Replied by Scimike on topic problems by starting up
I know they can differ, but my experience is they will start well within 2-3 second first turn. I would start by checking the plugs / service state, I know its new to you, but the previous owner (or garage) may have just ignored this. Also get the battery checked, Halfords will check it for free if you ask, so no need to book into a garage.
all the best
Mike
all the best
Mike
Last edit: 09 Nov 2022 12:57 by Scimike.
- Thank you received: 663
09 Nov 2022 13:29 #245849
Replied by DrRobin on topic problems by starting up
First cold snap the AA & RAC are rushed off their feet going to cars that won't start, it is nearly always battery.
When it's cold,
- the engine takes more starting (has to be turned over for longer),
- the oil is thicker,
- the starter motor current is higher,
- the battery's output is typically lower, especially peak current.
Even a good battery can struggle to start a cold engine if it is less than 20% charged and if it is more than 3 years old, that is probably your problem. The battery should be date coded, worth a check.
Also depress the clutch when starting it removes a little load.
When it's cold,
09 Nov 2022 18:09 #245854
by dave55555
guys thanky you all for the tips... I ll go thorough through everything and let You know .
in the meantime all the best and tx a lot
Time to create page: 0.250 seconds
