problems by starting up
  • dave55555
4 years 1 week ago - 4 years 1 week ago #245820 by dave55555
problems by starting up was created by dave55555
hi everyone, i m new on this forum, so please I beg your pardon if I might do some mistakes.
i recently boght a suzuki jimny 2013 1.3l  m13engine
i discovered at once that when the engine is cold it takes a few sec more to fire up. Today (temperature 6 celsius) the engine didn't fire up at once but on the second try.
what could be the cause of this?
tx in advance
Last edit: 4 years 1 week ago by dave55555.
4 years 1 week ago #245821 by CB1289
Replied by CB1289 on topic problems by starting up
Bad battery perhaps? Maybe if it's not too great anyway and then with the cold weather it could be causing your problem
  • dave55555
4 years 1 week ago #245822 by dave55555
Replied by dave55555 on topic problems by starting up
hi CB, i don't think so... the starter turns with no problems and doesn't sound bad at all. it just doesn t fire up at once
4 years 1 week ago #245824 by fordem
Replied by fordem on topic problems by starting up
Do you know how old the battery is - don't be too quick to dismiss the idea - especially if you're in a colder climate - the additional load cranking a cold engine over with a cold battery can allow the battery voltage to drop just enough that it doesn't fire.
On the second attempt the current through the battery from the first attempt warms it enough. that it delivers more power.
At least look at the battery voltage whilst cranking to see how far it drops, anything lower than around 9~10V and you just might have found the problem.
4 years 1 week ago #245827 by Lambert
Replied by Lambert on topic problems by starting up
When you say doesn't fire for a few seconds what are you talking about 5, 15, 30 seconds of churning or what? They don't just spring off the first touch of the key especially when cold, not like a Toyota that you almost only need to think about turning the key to be running.
  • dave55555
4 years 1 week ago #245841 by dave55555
Hi fordem tx for the tip. Gonna check it asap
