getting better mpg
28 Jul 2022 02:23 #244251
by danielbz
Replied by danielbz on topic getting better mpg
US gallon
91 octane, no ethanol
- Thank you received: 1949
28 Jul 2022 03:31 #244252
Replied by Lambert on topic getting better mpg
Driving down hill in neutral that is coasting is not good. First it reduces your control of the vehicle as you have no engine braking effect which in turn increases reliance on the wheel brakes which can cause them to overheat. Secondly the engine will revert to idle in neutral which requires it to burn fuel, when going down hill in gear the ECU detects this and virtually stops fuel supply, the effect may be small but it does increase mpg.
28 Jul 2022 04:40 #244253
by Old Neil
Replied by Old Neil on topic Re:getting better mpg
Can you use 91 in a series 4 my series 3 staits minimum 95 ?
Sent from my SM-A336E using Tapatalk
- Doctorchris
- Senior Member
- Thank you received: 13
28 Jul 2022 07:06 #244254
by Doctorchris
Replied by Doctorchris on topic getting better mpg
Your US gallon figure converts to nearly 35 mpg in Imperial measures, which is better.
I often achieve 45 mpg but that is on smooth tarmac, change up quickly through the gears and keep speeds low.
28 Jul 2022 07:47 #244255
by saxj
Replied by saxj on topic getting better mpg
Great theory, but in practice coasting in neutral uses less fuel.Driving down hill in neutral that is coasting is not good. First it reduces your control of the vehicle as you have no engine braking effect which in turn increases reliance on the wheel brakes which can cause them to overheat. Secondly the engine will revert to idle in neutral which requires it to burn fuel, when going down hill in gear the ECU detects this and virtually stops fuel supply, the effect may be small but it does increase mpg.
- Bill Portland
- Thank you received: 77
28 Jul 2022 08:17 #244256
by Bill Portland
Replied by Bill Portland on topic getting better mpg
My very standard gen 4 still achieving a lifetime average of over 42mpg (UK). No motorways near me but otherwise regular A & B road driving. I rarely cane it though.
Time to create page: 0.182 seconds
