getting better mpg
28 Jul 2022 09:14 #244257 by Lambert
Replied by Lambert on topic getting better mpg
Driving down hill in neutral that is coasting is not good. First it reduces your control of the vehicle as you have no engine braking effect which in turn increases reliance on the wheel brakes which can cause them to overheat. Secondly the engine will revert to idle in neutral which requires it to burn fuel, when going down hill in gear the ECU detects this and virtually stops fuel supply, the effect may be small but it does increase mpg.
Great theory, but in practice coasting in neutral uses less fuel.
Maybe on a carburettor motor but it's one of the ways modern European compliant engines meet emissions.
28 Jul 2022 12:04 #244258 by danielbz
Replied by danielbz on topic getting better mpg
so, does going on D shuts down fuel injection? where can i see that??
and going on N does not stops fuel injection? i didnt know about that, is there somewhere i can check this?
28 Jul 2022 12:12 #244259 by RumbleAndSway
Replied by RumbleAndSway on topic getting better mpg
37.8 mpg from SZ5, running BFG AT, roof bars, bike carrier, awning and occasionally a roof load [bike, ladder, canoe etc.]
Never seen 40mpg but no grounds for complaint.
28 Jul 2022 13:32 #244261 by DrRobin
Replied by DrRobin on topic getting better mpg
An imperial gallon is 20% bigger, so that takes your 29 to almost 35mpg.
I don't have any figures for 91 octane rating vs 95 we get in the UK, but would expect another increase in mpg, possibly as much as 5%. So that takes you up to about 36.5mpg.
The ECU needs to be able to adjust to the different octane ratings, but I assume they do this, or the ECU is 'tuned' for the market the vehicle is going in to.
Several years ago I hired a Jimny on holiday in the Caribbean, it seemed to drink fuel and it wasn't cheap, so I worked out the mpg, it wasn't very good, I put it down to the state of the roads. Only later did I realise that although the island used to be under British rule, pertrol was sold in US gallons.
I think you are not that far away. You might check the air filter or the CAT might have disintegrated, then again check the plugs and everything else, depending on how many miles your vehicle has done.
Robin
28 Jul 2022 14:37 #244263 by saxj
Replied by saxj on topic getting better mpg
Yes it does. You can see it on the instant consumption gauge on the Gen 4.
28 Jul 2022 14:42 - 28 Jul 2022 14:45 #244264 by saxj
It's all about friction and momentum, you go further in neutral than you will with your foot off the throttle, so it uses less fuel. I used to live in a hilly area, and it used to make quite a difference to my consumption - Gen 3 manual and Gen 4 Auto. Now I live in a very flat area, so I don't get the advantage any more.
Last edit: 28 Jul 2022 14:45 by saxj.
Time to create page: 0.260 seconds
