getting better mpg
28 Jul 2022 15:10 #244265 by 300bhpton
Replied by 300bhpton on topic getting better mpg
im using a non traffic road, i drive 50 mph when going uphill and i go downhill in N, im not in the UK, what mods do you have?
ATs, winch bumper and some other bits.
Is your vehicle standard?
I assume if putting it in N it is a manual not an automatic.
28 Jul 2022 15:11 #244266 by 300bhpton
US gallon
91 octane, no ethanol
Curious, where are you?
Do you know what Octane scale you use?
91 octane in the USA at least, would be about the same as 95RON here in the UK.
28 Jul 2022 15:14 #244267 by 300bhpton
Replied by 300bhpton on topic Re:getting better mpg
Can you use 91 in a series 4 my series 3 staits minimum 95 ?
Sent from my SM-A336E using Tapatalk
Depends where in the world they are. Octane is rated in different ways.
en.wikipedia.org/wiki/Octane_rating
The following user(s) said Thank You: Old Neil
28 Jul 2022 15:15 #244268 by 300bhpton
My very standard gen 4 still achieving a lifetime average of over 42mpg (UK). No motorways near me but otherwise regular A & B road driving. I rarely cane it though.
I'd suggest over 40mpg is not the norm for most Jimny's. You really do need to drive it very gently to attain that (never managed it in mine, even when 100% stock).
28 Jul 2022 15:16 #244269 by 300bhpton
Driving down hill in neutral that is coasting is not good. First it reduces your control of the vehicle as you have no engine braking effect which in turn increases reliance on the wheel brakes which can cause them to overheat. Secondly the engine will revert to idle in neutral which requires it to burn fuel, when going down hill in gear the ECU detects this and virtually stops fuel supply, the effect may be small but it does increase mpg.
Great theory, but in practice coasting in neutral uses less fuel.
No, neutral will be at idle and still pumping fuel in. Using engine braking will be no fuel and potentially more economical.
28 Jul 2022 16:16 #244271 by danielbz
Replied by danielbz on topic getting better mpg
i was going down in N, my car is automatic, i will take into consideration what you told me, knowing that modern cars have more stuff included it may be true that going down in D stops fuel injection, i just had not thought about that before, thanks
Time to create page: 0.176 seconds
