Re:Re:Changing the atf
26 Jan 2022 22:29 #241523 by Old Neil
Replied by Old Neil on topic Re:Changing the atf
Lambert wrote: Ok I did wonder if that might be the case. I guess I'll monitor it at service and see if it deteriorates over time and "change" it if it becomes too discoloured. Cheers.
Lambert do you run transmission cooler in old Blythe, can't you take return line off trans cooler put clear flexible tubing on return line into container rubber bung on trans then idol engine till you see bubbles stop refill repeat with clear tubing you can see fluid colour change and monitor how much fluid goes into container?
27 Jan 2022 04:22 #241527 by Lambert
Replied by Lambert on topic Re:Changing the atf
That has potential as an idea. Will look into it thanks.
27 Jan 2022 10:34 #241531 by Old Neil
Replied by Old Neil on topic Re:Re:Changing the atf
Lambert wrote: That has potential as an idea. Will look into it thanks.
You have the ability to tweak it so that it works for you, bit of head scratching
27 Jan 2022 14:35 #241532 by Roger Fairclough
Is the colour of the fluid something to be alarmed about?
Roger
27 Jan 2022 17:21 #241533 by thieuster
Replied by thieuster on topic Re:Re:Changing the atf
Lots of videos on the internet about ATF colours. Interesting stuff!
Chronologically:
- 1959 Triumph TR3A
- 1970 Saab 96V4
- 1973 Saab 95V4
- 2001 Suzuki Jimny
- 2020 Honda CR-V Hybrid 4x4
Gone:
- 1973 Porsche 914
- 1993 Suzuki Samurai
New:
- 1991 Peugeot 205 automatic with < 60K miles!
29 Jan 2022 04:11 #241555 by Lambert
Replied by Lambert on topic Re:Re:Changing the atf
Colour and smell yes, atf should be a nice medium red. It should not be dark nor should it smell like burned toast.
Also heard from my other local dealer and they acknowledge that there is a filter and are quite happy to take 316 quid off me whenever I want the atf changing. Expensive by my standards but probably actually cheaper in the long run than me laid on my back taking a bath in oil on my drive.
