Re:Re:Changing the atf
- Roger Fairclough
- Thank you received: 218
29 Jan 2022 09:30 #241556
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Re:Changing the atf
My post wasn't quite clear enough, so I will re-write it.
"Is the colour of your fluid something you are alarmed about."
Roger
Roger
- Thank you received: 1941
29 Jan 2022 10:27 #241558
Replied by Lambert on topic Re:Re:Changing the atf
No not yet but I will be monitoring it at service to ensure it doesn't become a worry.
29 Jan 2022 11:28 - 29 Jan 2022 11:30 #241560
by LesNewell
Replied by LesNewell on topic Re:Re:Changing the atf
Changing the filter is a pretty easy job. Drain the oil and drop the sump (it's just held on with a ring of bolts). The filter is held in with one bolt. While you are in there it's a good opportunity to check the magnet on the sump for metal shavings.
You will need a filter, sump gasket and filter o-ring. For some reason most filter kits don't include that o-ring.
If your oil is nasty you can drain/refill the box, run it for a few minutes then repeat a couple of times. This flushes most of the old oil out of the torque converter. It's a bit tedious and wastes a lot of oil but it does the job.
Last edit: 29 Jan 2022 11:30 by LesNewell.
29 Jan 2022 12:07 #241562
Thanks, that makes 316 quid seem expensive.
21 Feb 2022 21:13 - 21 Feb 2022 21:15 #241959
by Stainless
Replied by Stainless on topic Changing the atf
Agree fully with Lambert, our 2006 Jimny hasn’t been anywhere near a main dealership since 2008. At least you know the job is done properly if you can do it yourself, and save a fortune too.
Last edit: 21 Feb 2022 21:15 by Stainless. Reason: Grammar
Time to create page: 0.204 seconds
