Re:Bite point
06 Nov 2021 09:22 #239898 by Roger Fairclough
Replied by Roger Fairclough on topic Re:Bite point
Coming from a big diesel, I had to adjust to a high speed petrol with a light flywheel so yes, you will need to adjust. As a matter of interest I bent the clutch pedal slightly to the right to allow me to put my left foot in a more comfortable position to the left of the pedal, and yes, I also have to select my footwear so that I do not foul the brake pedal when operating the throttle.
Roger
06 Nov 2021 20:29 #239910 by Lambert
Replied by Lambert on topic Re:Bite point
I take a size 12 and wear work boots and or wellingtons everywhere and the pedal position on my old gen3 was never a problem. However having now got the automatic gearbox I will not be going back to a clutch.
06 Nov 2021 21:39 - 06 Nov 2021 21:42 #239913 by Scimike
Replied by Scimike on topic Re:Bite point
Not suggesting you can't wear boots and drive a Jimny, just indicating that your shoe selection can impact the way you interact with the vehicle.
I suspect that's why F1 drivers tend to steer clear of Wellington's, the cars are difficult to get off the line without stalling also
Last edit: 06 Nov 2021 21:42 by Scimike.
06 Nov 2021 22:08 #239914 by Roger Fairclough
Hi Scimike.
Noticed you use Yokohama Geolanders. I would be interested in the size you use and what you think of them.
cheers
Roger
06 Nov 2021 22:24 - 07 Nov 2021 09:51 #239916 by Scimike
Hi Roger,
I run them in standard size for the G3,  205/70R15.
My primary use is road and the conditions that entails. They don't produce any more road noise than the summer tyres previous fitted, I've also not seen any reduction in mpg. In the dry or wet they just grip, no surprise skids or slips, even with my caravan on the back. Last year in the snow they proved to be a revelation. Never had snow rated types before and the difference to none rated is amazing. No side slipping or wheel spinning, in fact they made driving on snow effortless. I will never fit none snow rated tyres again. I don't off-road as such in my Jimny, but grass / mud covered slopes aren't an issue, I suspect they would be fine in more severe conditions. But I have my Land Rover for this with MT tyres etc.
So for me they are perfect and I will be fitting again.
Last edit: 07 Nov 2021 09:51 by Scimike.
The following user(s) said Thank You: Roger Fairclough
07 Nov 2021 22:51 #239938 by Roger Fairclough
Hi Scimike.
Many thanks for the info. I will be considering a set of winter tyres fitted to steelies and the Geolanders sound perfect.
Roger
Time to create page: 0.095 seconds
