Re:Bite point
- Jako999
05 Nov 2021 23:09 #239892
by Jako999
Bite point was created by Jako999
Well I’ve had my 2019, 6000 mile Jimny for a week now and it’s great fun but I can’t seem to get the bite point right in first gear it either almost stalls or I over Rev it is this normal? It drives well. I can normally just jump into anything and drive without a problem, so is it me or is it my new toy.
Thanks
Thanks
06 Nov 2021 00:14 - 06 Nov 2021 00:16 #239893
by Scimike
Replied by Scimike on topic Bite point
Hi,
I don't recall this being discussed as an issue for the Gen3 or Gen4, but those with G4's will confirm or not.
It's not something that happens on my G3, but it's sensitive (ok I am) to the footwear I choose. The pedal spacing is typical Jap, so chunky footwear makes clutch control more challenging. Boots pretty much press all pedals at once Big feet and small pedals, not a good combination.
That said it's also possible something is wrong, the user manual has a clutch pedal adjustment figure (10mm), or at least the G3 manual does. Is there similar in the G4 manual, if so it's something you can check.
Any chance of getting a second opinion from another driver?
Hope you enjoy.
Hope you enjoy.
Last edit: 06 Nov 2021 00:16 by Scimike.
06 Nov 2021 00:56 #239894
by fordem
Replied by fordem on topic Bite point
My temptation is to say it's you & give it time you'll get accustomed to it.
The gen 3 is a cable operated clutch which requires periodic adjustment, the gen 4 is self adjusting hydraulic - the bite point on my gen 4 is relatively close to the floor and has never given me any trouble, it's very similar to that of my second gen Grand Vitara.
The third manual transmission vehicle we have here is a turbo-diesel Nissan on which the bite point is a lot higher up than either of the Suzukis, that will occasionally give me trouble, I suspect because I drive it less frequently than I do the Suzukis.
06 Nov 2021 06:41 #239895
Replied by mlines on topic Re:Bite point
We jump in and out of both our gen3 and two gen4 regularly.
I have no problem with the clutches in any of them. The throttle in the gen4s has a different response action so I certainly over rev it, usually on start up when it actually needs no throttle at all and I have pressed the gas slightly to " help it start"
I do think it is possible to find a point in the clutch where the clutch plate "vibrates"
Sent from my moto g31(w) using Tapatalk
06 Nov 2021 07:14 - 06 Nov 2021 09:15 #239896
by DJ20
Replied by DJ20 on topic Re:Bite point
When I road tested my 2020 Jimny at the dealer I stalled it straight away and have a few times since. Sometimes I feel I might over rev it as compensation to stop it stalling.
I think coming from my previous diesel vehicles which have a lot more low end torque so you don’t tend to stall them very often (especially a Land Rover Defender), then the Jimny is definitely easier to stall.
But you will soon get used to it and adapt to suit.
Last edit: 06 Nov 2021 09:15 by DJ20.
06 Nov 2021 07:19 - 06 Nov 2021 07:21 #239897
by DJ20
Last edit: 06 Nov 2021 07:21 by DJ20.
Time to create page: 0.117 seconds
