E10 petrol
02 Sep 2021 08:10 #238152
by facade
Replied by facade on topic E10 petrol
Esso Synergy Supreme 99 is ethanol free (except in Devon, Cornwall, North Wales, North England and Scotland). It is a lot more expensive, but as I'm doing virtually zero mileage, it isn't going to separate in the tank.
- Thank you received: 2004
02 Sep 2021 15:28 #238162
Replied by Lambert on topic E10 petrol
Sorry am I missing something here? Jimny run just fine on e10 fuel. Mine even has a sticker inside the fuel flap saying to use it.
03 Sep 2021 06:48 #238174
by Busta
Replied by Busta on topic E10 petrol
I predict that every single engine fault in the next 3 months will be blamed on the 5% increase in the amount of ethanol in the petrol.
03 Sep 2021 07:00 #238175
Replied by mlines on topic Re:E10 petrol
It's been in wide use in a number of countries for a good few years
Sent from my motorola using Tapatalk
03 Sep 2021 10:53 #238179
by facade
Replied by facade on topic Re:E10 petrol
In The Olden Days my father used to run our Rover 90 on Cleveland Discol, which was adulterated with ethanol- as an octane booster.
Never caused any problem (cars were made properly then, with lead and proper rubber from the colonies), except I do recall breaking down on the way to Aberystwyth with fuel pump failure......
I'm not bothered by running on e10, just by what happens when it stands in the fuel tank for weeks on end.
You can remove the ethanol, by sloshing in a bit of water, then using a separating funnel to run the water/ethanol off from under the petrol, but I suspect the novelty wears off after the second gallon.
- Mr CC
29 Oct 2021 23:22 #239735
by Mr CC
Replied by Mr CC on topic E10 petrol
just looked in my manual for 2001 it quotes "blends of unleaded petrol and ethanol (grain alcohol), also known as gasohol, are commercially available in some areas. Blends of this type may be used in your vehicle if they are no more than 10% ethanol. Be sure this petrol- ethanol blend has octane ratings no lower than those recommended for petrol" so this makes my jimny suitable for E10. Pretty well pleased after worrying that the restoration might be short lived.
Time to create page: 0.122 seconds
