E10 petrol
- Mr CC
29 Oct 2021 23:33 #239736
by Mr CC
Replied by Mr CC on topic E10 petrol
to add as well it may be possible the ecu can be adapted to use other mixtures. but I haven't studied too hard on that, so don't take it as gospel.
30 Oct 2021 11:03 #239741
by Busta
Replied by Busta on topic E10 petrol
The Jimny engine has a knock sensor, so it can adapt the timing to some extent. Suzuki specify 95RON so I assume the knock sensor is there to save the engine if lower octane fuel is used.
- Podge
30 Oct 2021 13:31 #239744
by Podge
Replied by Podge on topic E10 petrol
I ran a tank of E10 95 and a tank of E5 97 octane and I can't say I noticed any power difference and MPGeees was still 32-33.
30 Oct 2021 13:44 #239745
by Busta
I think most of the instances of people noticing an improvement when using higher octane fuel are due to the extra cleaning additives most premium fuels contain, essentially restoring performance lost over time rather than giving extra.
Ethanol is a very good cleaning agent and will help to maintain performance, so occasionally running a tank of premium won't yield the same results it used to.
- Thank you received: 2004
30 Oct 2021 16:08 #239749
Replied by Lambert on topic E10 petrol
I'm finding that the mpg of Temeraire is starting to stabilise and is getting closer to what I expected from an automatic on less energy dense fuel. I am putting this down to the cleaning effect of the additional ethanol and the after effects of a running in period that probably didn't involve the top half of the rev range. I could easily believe that much of the inlet system was filthy so e10 is currently not causing me too much concern.
31 Oct 2021 10:06 #239756
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Replied by me101 on topic E10 petrol
Am I reading this correct, and the new E10 is actually cleaning the fuel lines / intake? Does this mean I don't need the Redex stuff anymore?
Cheers
Cheers
Time to create page: 0.099 seconds
