Supercharger for Gen 4's
- Thank you received: 1992
28 Jul 2021 04:34 #237067
Replied by Lambert on topic Re:Supercharger for Gen 4's
Be careful with that, it's how you get carbon buildup. These little short throw motors need high revs to work efficiently. The upper shift point on Temeraire is 6k.
The topic has been locked.
28 Jul 2021 08:01 #237069
Replied by Soeley on topic Supercharger for Gen 4's
How have they got an extra 50 horses without remapping? I wonder how long the engine/transmission will last compared to standard?
28 Jul 2021 08:15 #237071
by Busta
Replied by Busta on topic Re:Supercharger for Gen 4's
They you can have the easiest power upgrade ever. Simply use the full potential of the standard engine and you will gain 50% more power!l am not sure l've ever been past 3,500rpm on ours!
- Thank you received: 230
28 Jul 2021 08:22 #237072
by 300bhpton
Supercharger type will dictate how the power curve looks. A centrifugal blower is a big snail shell design and looks like a large turbocharger, only being belt driven. These are 100% rpm dependant, so they will make less boost when being spun slowly and in theory will continue to make more and more power the faster you spin it. Offering bigger gains at high rpm.
Positive Displacement (PD) blowers such as Roots or Twin Screws have the ability to make full boost just off idle and will give the low end fat torque curve. But roots blowers are less efficient as a rule, so will make less Peak power. And often drop a bit of boost at high rpm. Twin screws are more efficient and tend to hand on better at high rpm. But will still be behind a good centrifugal blower on Peak power.
Personally I'm of the mind that a PD blower would suit something like the Jimny more so. But I'm not sure there is anyone looking at building a kit using these.
Replied by 300bhpton on topic Re:Supercharger for Gen 4's
Interesting. Not a lot gained at the bottom end, but the supercharger keeps the torque rising where the standard engine plateaus at 3,500rpm, leading to a big difference at the red line. This will really change how the engine feels above 3,500rpm. Worthwhile for people that are finding the engine a bit flat at higher RPM.
28 Jul 2021 08:23 #237073
by Busta
Replied by Busta on topic Supercharger for Gen 4's
Soeley, my Taiwanese isn't the best but I didn't hear them say they hadn't re-mapped it? I'd be very suprised if HKS were cutting any corners.
- Roger Fairclough
- Thank you received: 225
28 Jul 2021 08:48 #237074
by Roger Fairclough
Replied by Roger Fairclough on topic Supercharger for Gen 4's
Carbon build up! Maybe 50 years ago but with modern oils and fuel?
Roger.
Roger.
Time to create page: 0.228 seconds
