Supercharger for Gen 4's
- Thank you received: 230
06 Jul 2021 15:28 - 06 Jul 2021 15:29 #236455
by 300bhpton
Supercharger for Gen 4's was created by 300bhpton
Got emailed this today (pdf attached). Company is in Oz, but hopefully something will be available here in the UK at some point. If I'm converting Aus $ to Sterling correctly, it works out at about £5k, which is comparable to supercharger kits for other marques.
Not saying the Jimny is slow, but a bit more grunt would be nice. I plan to keep my SZ5 long term, so once out of warranty I'd maybe consider something like this. Hopefully by then they will be available with a few people having run them successfully.
www.rotrex.com
www.bulletcars.com
www.rotrex.com
www.bulletcars.com
Last edit: 06 Jul 2021 15:29 by 300bhpton.
The topic has been locked.
06 Jul 2021 15:32 #236457
by lightning
Replied by lightning on topic Supercharger for Gen 4's
A supercharged Jimny sounds fun, although l have a feeling it would make the handling a bit scary on a wet road.
06 Jul 2021 15:41 #236459
by 300bhpton
Although quite a few V8 powered Series Land Rover's about. Which weigh very similar to the Jimny. I had a Series 3 with a Tdi in, probably made more low end torque than the supercharged Jimny would.
Also got a 3.9 V8 powered TR7 which probably weighs less than a Jimny. With the traction and stability control on the 4th Gen Jimny, I can't see it really being an issue.
Replied by 300bhpton on topic Supercharger for Gen 4's
Maybe.A supercharged Jimny sounds fun, although l have a feeling it would make the handling a bit scary on a wet road.
06 Jul 2021 18:52 - 06 Jul 2021 18:53 #236462
by lightning
ls the Land Rover Series 3 full time 4wd? The Jimny is only 2wd on road.
With full time 4wd you can put a lot more power down safely.
Last edit: 06 Jul 2021 18:53 by lightning.
06 Jul 2021 19:09 #236463
by 300bhpton
Series Land Rovers are much like the Jimny and rwd only on the road.ls the Land Rover Series 3 full time 4wd? The Jimny is only 2wd on road.
07 Jul 2021 07:10 #236470
by Busta
Replied by Busta on topic Supercharger for Gen 4's
For that price I'd be looking at an engine swaps. Lots of good 2.0 engines that could go in.
Unless they are replacing the throttle pedal with an on-off switch I can't see handling being a big problem.
