Bonnet scoop?
- Thank you received: 2004
26 Jun 2021 12:13 #236159
Bonnet scoop? was created by Lambert
Whatcha. Before I get busy with the micro grinder do we know if anyone sells either a mesh or louvre replacement for the blanking plate on the bonnet scoop gen3? I ask as yesterday I had my first significant punt along the motorway and on reaching my destination there was significant heat escaping through the panel gaps around the bonnet which is leading me to think that additional ventilation might not be unreasonable. I accept that it would promote the ingestion of rain into the engine bay but the amount of heat generated would soon evaporate all but the very worst. Also I am not a fan of fake air ducting so if its there it might as well be functional.
26 Jun 2021 12:56 #236160
by Busta
Replied by Busta on topic Bonnet scoop?
Personally I'd just get rid of the vent. It doesn't do anything and doesn't need to be there. I can't see any advantage of extra cooling either. Engines generate heat, it's not a problem.
26 Jun 2021 13:43 #236162
Replied by Lambert on topic Bonnet scoop?
It's moulded into the bonnet skin. Removing is not an option.
26 Jun 2021 17:26 #236164
by Scimike
Replied by Scimike on topic Bonnet scoop?
They must have something, but failing finding OEM, stainless steel rodent mesh (various hole sizes available) looks good and can be shape easily. My 2CV has it as standard over the air intake (it's a Citroen part!)
- Thank you received: 227
27 Jun 2021 00:44 #236170
by zukebob
Replied by zukebob on topic Bonnet scoop?
From one of the locals here in the Philippines that has access to a laser cutter:
Isn't a normal stock item but I could inquire. From memory, cost was equivalent to about $20 USD.
I would agree with Busta that it isn't necessary. I think the only reason I did it was that I didn't see the point in having a hood scoop that was blocked.
The following user(s) said Thank You: Lambert, Darthblaker7474
27 Jun 2021 05:56 #236171
I would suspect that postage costs would render that unviable? I agree that if Suzuki though it was necessary they would have done it themselves but I too have issues with fake vents and aero.
