Clutch pedal
09 May 2021 21:40 #234943
by Stefan
Replied by Stefan on topic Clutch pedal
Yes, ever since I bought it, it was like this, that is why I thought that maybe it has a knack to it, but wanted to hear from you guys that actually know the Jimny well. It has close to 170 000 km on the clock now, with no indication it has ever been changed.I'm the third owner, and judging about how extremely dirty and rusty looking the chassis and under carriage is suggests it has done some offroading a lot too. I did replace the leaking rear diff pinion seal, so is that an indication of wear on other parts?
I'll try it some more tomorrow and see what it does for what it's worth.
10 May 2021 16:32 #234949
by Stefan
So as Roger says about clutch slip that would kick in at some point. So where abouts should I change gears? Currently I find 3000 rpm to be smooth for the engine when changing as it does'nt stutter or anything.
10 May 2021 16:55 - 10 May 2021 16:57 #234950
by Scimike
Replied by Scimike on topic Clutch pedal
If that rpm works for you and your Jimmy then I would say that's perfect.
Its a personal thing, the Jimmy engine is very responsive over the entire rev range.
I tend to shift before 3000 as it suits my driving style, but I have shifted near the redline on hills with my caravan on the back. Jimmy is happy at both ends to be honest, short shifting or revving it hard, it makes no difference to the engine.
Last edit: 10 May 2021 16:57 by Scimike.
- Roger Fairclough
- Thank you received: 225
10 May 2021 20:27 #234954
by Roger Fairclough
Replied by Roger Fairclough on topic Clutch pedal
Torque is what causes a dying clutch to finally give up the ghost, so if you find out where max. torque is and stay away from it you will get the max life out of the clutch.
But the inevitable will catch you up. Try this. Try a rapid start with 4,000 rpm and before the clutch is fully engaged dip the pedal slightly. A good clutch will cope and grip, a well worn one will see the revs soar. Now back off the power and the clutch will struggle to cope. If it does this get it changed. All this assumes the clutch is correctly adjusted.
Roger
Roger
- justintime441
11 May 2021 01:21 #234957
by justintime441
Replied by justintime441 on topic Clutch pedal
Are you new to driving manual? If so, get someone who knows how the clutch should feel and let them drive it.
11 May 2021 09:24 - 11 May 2021 09:25 #234960
by lightning
Replied by lightning on topic Clutch pedal
His Jimny has done 170,000 km
l would say with some degree of certainty that the clutch at the end of its life and he needs a new one fitted.
Last edit: 11 May 2021 09:25 by lightning.
Time to create page: 0.326 seconds
