Clutch pedal
11 May 2021 12:09 - 11 May 2021 12:10 #234971 by Stefan
Replied by Stefan on topic Clutch pedal
Thank you for the input. I'll need to make absolute sure about the case before stating it to my father (owner). He will just say it can't be, so I'll need solid proof, and he doesn't like what people suggest on the internet.
Last edit: 11 May 2021 12:10 by Stefan.
11 May 2021 12:12 - 11 May 2021 12:12 #234972 by Stefan
This Jimny hardly accelerates above 3000 rpm except in 5th gear I can get to 100km/h at about 3200 rpm.
Last edit: 11 May 2021 12:12 by Stefan.
11 May 2021 17:33 - 11 May 2021 17:33 #234981 by Lambert
Replied by Lambert on topic Clutch pedal
Then it needs an Italian tune up also known as a good long thrashing up a motorway. When I first got my current Jimny off my parents it too didn't like the top of the rev range, it got much better for being used properly. A Jimny is not a big lumbering diesel it has more in common with a sports bike.
Last edit: 11 May 2021 17:33 by Lambert.
12 May 2021 17:19 #235003 by Riccy
Replied by Riccy on topic Clutch pedal
That proves what Lambert is saying. They need revs and lots of them to get the best from the engine.
The M series engine when properly tuned doesn't start to do anything interesting before 3000 rpm. If its VVT then that kicks in at about 4000 meaning they are clearly intended to be up in the revs before any action. Theres plenty of M series engines flying about in swifts with a 8000+ rev limiter set. Ive set mine at 6600, which is very conservative for what it can do.
Italian tune up time without telling the owner ;-)
13 May 2021 17:24 #235015 by Stefan
Need to check what type mine is, think it's an M type. What's with the 16 valves in such a small engine too?
I'll try the Italian tune up, just don't have a lot of open roads out here in the country.
Time to create page: 0.199 seconds
