Clutch pedal
11 May 2021 10:45 #234963
by Stefan
Replied by Stefan on topic Clutch pedal
New to driving a Jimny, and a petrol vehicle for that matter. But not new to manual. Been driving manual diesels most of the time before I got the Jimny.
11 May 2021 10:48 #234964
by Stefan
Guess it's time then. Assuming it has never been changed before I got it by the other two owners.
11 May 2021 10:53 #234965
by Stefan
Didn't know that.
Must I revv up to 4000 in first gear?
I don't know if it is adjusted correctly. I'll just have to send it to Suzuki either way.
11 May 2021 10:56 #234966
by Stefan
Alright, sounds promising. I did short shift at first but after I had exhaust leaks to repair and did some googling I found short shifting is a bit bad for the cats, my father told me 3000 is best for petrol engines.
- Roger Fairclough
- Thank you received: 225
11 May 2021 11:34 #234968
by Roger Fairclough
Replied by Roger Fairclough on topic Clutch pedal
I suggested 4,000 rpm as that should be at about max. torque but as others have said, it sounds as if a new clutch is the order of the day.
Roger
Roger
- Thank you received: 1999
11 May 2021 11:53 #234970
Replied by Lambert on topic Clutch pedal
The vvt doesn't come on till around 4000 rpm and is good for another 2000 rpm after that. These are small engines and need many rpm to make power and torque. Don't be afraid of the top half of the rev range.
Time to create page: 0.488 seconds
