JB74 Rattling noise driving me crazy.
- epc2
16 Feb 2021 03:19 #232821
by epc2
JB74 Rattling noise driving me crazy. was created by epc2
Hi guys,
Wanted to check if any of you have had a similar experience , I have a 2020 Jb74 , OME lift kit with 235/75/15 tyres and stock rims.
I have an annoying ratling noise in teh back that has been increasing in the last few weeks and after checking all the possible causes , I have narrowed it down to the spare wheel/wheel mount , don't know if it's the mount tha's deffective or if the tyre is too big and heavy or what the heck is going on but it's driving me crazy for sure , everytime I drive on uneven surface or bumps it rattles and it's very annnoying.
After checking everything in the back I decided to remove the tyre and w/o the tyre it doesn't rattle at all , I don't have the lightest tyre @37lbs but i know guys that have tyres heavier than mine and with bike racks,loads etc and have 0 issues.
Just wanted to check if any of you guys had a similar experience and how did you resolve it.
Thanks in advance.
Thanks in advance.
- Thank you received: 1984
16 Feb 2021 06:29 #232824
Replied by Lambert on topic JB74 Rattling noise driving me crazy.
Welcome to the forum. When you took the spare off I assume you did a spanner check of the bolts holding the carrier to the door and everything was tight? Also it might be worth popping the door trim off the inside and checking for anything obvious like a fatigue crack?
16 Feb 2021 07:16 #232825
Replied by Soeley on topic JB74 Rattling noise driving me crazy.
Do you still have the standard spare wheel cover on? If you have removed it, it could be the small bracket that it fixes to as it fits between the spare wheel holder and spare wheel. I think the wheel cover pulls it tight when the nut is done up.
16 Feb 2021 07:33 #232826
Replied by mlines on topic Re:JB74 Rattling noise driving me crazy.
It's a bit early in its life, but heavier tyres on the door affect the hinges and door lock.
- Roger Fairclough
- Thank you received: 225
16 Feb 2021 11:07 #232839
by Roger Fairclough
Replied by Roger Fairclough on topic Re:JB74 Rattling noise driving me crazy.
I suggest you put the wheel/tyre back on and then manually rock the wheel/tyre to try and narrow the noise down. if still not sure remove door trim and see if that helps. A stethoscope could be very useful.
Roger
Roger
- epc2
16 Feb 2021 13:24 - 16 Feb 2021 13:25 #232846
by epc2
Replied by epc2 on topic JB74 Rattling noise driving me crazy.
Lambert wrote: Welcome to the forum. When you took the spare off I assume you did a spanner check of the bolts holding the carrier to the door and everything was tight? Also it might be worth popping the door trim off the inside and checking for anything obvious like a fatigue crack?
Thanks , very nice community with lots of info,Yeah all the bolts are tight I checked them.
Last edit: 16 Feb 2021 13:25 by epc2.
Time to create page: 0.219 seconds
