GEN 4 Seat Belt fraying
12 Nov 2020 08:22 #229958 by lightning
Replied by lightning on topic GEN 4 Seat Belt fraying
That's bizarre.
With the the belt in normal use there shouldn't be enough tension on it to do that in such a short time. Unless there's a sharp piece of metal or something behind the trim where the belt goes.
Where on the belt is the damaged part? As in, where does it sit when retracted, and in use.
l would take the Jimny bask to your dealer and see what they say.
12 Nov 2020 15:05 #229963 by Bob1050
Replied by Bob1050 on topic GEN 4 Seat Belt fraying
Thought for a moment that I had logged onto the Land Rover Defender Forum - frayed seatbelts are not unknown with Defenders and various products are available to prevent it happening. Never seen this problem on a Jimny - will check my own G4 later but will be shocked if it has started to fray. Have noted that my old Defender has had a couple of advisories for a frayed seatbelt at MOT time.
12 Nov 2020 17:35 #229964 by Scimike
Replied by Scimike on topic GEN 4 Seat Belt fraying
Fraying on seatbelts can be caused over time by repeated use or by a sharp edge/manufacturing fault, the photo to me looks like the latter. I don't believe it's a common fault in any vehicle, but this aside Lambert's correct in that it wants fixing asap.
Suzuki need to take a look to see if anything on your vehicle that is causing the issue or it's a manufacturing fault, should be easy enough if it's in warranty.
The only other factor is us, the user, did we damage it in anyway? Jamming it in the door mechanism of dragging along the road are all good routes to this type of damage.
Not implying any one method is the reason, simply looking a the various mechanism to belt failure of this type.
Hope you get it fixed.
13 Nov 2020 18:22 #229986 by Micheal
Replied by Micheal on topic GEN 4 Seat Belt fraying
Hi all, it's the wife that drives the Jimny, she noticed the belt getting difficult to pull down then that it was frayed like this. She says there have been no sudden events, trapping or dragging along the road.
Suzuki dealer suggests a very expensive bill, none of these in the country (!?), £200+ parts + labour +VAT thick end of £400 I imagine.
They are sending pics to Suzuki to see if they will replace under warranty, won't order the part from Japan unless paid in full in advance. I think we can sense where this is going.
It is a bit concerning that Suzuki have such parts costs and poor availability
Cheers
13 Nov 2020 18:25 #229987 by Micheal
couple of further photos attached
13 Nov 2020 18:30 #229988 by 300bhpton
Replied by 300bhpton on topic GEN 4 Seat Belt fraying
When wearing the belt, where is the frayed bit? Obviously this wouldn't help with a warranty claim. But could it have caught on a belt buckle or even something like a handbag strap or something.
Also when the belt is fully retracted, where is the frayed bit?
