GEN 4 Seat Belt fraying
20 Nov 2020 14:39 #230236 by Micheal
Replied by Micheal on topic GEN 4 Seat Belt fraying
Martin, further to your comment about someone new taking over at Suzuki GB in respect of warranty claims etc, the garage just told me that it is a lady (I'm not being sexist here!) who took over after the previous person retired and this garage has never had so many warranty claims rejected or queries as now. 'it's becoming a full time job' dealing with these claims is what he said and that increasingly Suzuki are rejecting the warranty claim and if it is what they think border line leaning on the garage to fit it foc as goodwill.
20 Nov 2020 14:53 #230237 by 300bhpton
Replied by 300bhpton on topic GEN 4 Seat Belt fraying
DrRobin wrote: Almost certainly this wear has occurred where the belt goes over a bearing or holder, but reading the posts it seems it is shoulder height when in use, so does it go into the trim and down to the reel when not in use or sits on the plastic covered D ring? I would be tempted to take the trim off, but guess you don't want to do that whilst it is a warranty claim.
If it stops at the d-ring, then it looks like this is the cause, but I suspect it is going down in to the trim and it is most likely catching on something behind the trim.
As it is the driver's side and sits around the shoulder when in use, I doubt your wife has metal blades on her clothes so it is normal use and when not in use the car isn't been driven so it can't be motion of the car with the belt rubbing against something.
As Lambert and other have said, this is dangerous and needs replacing.
I am not an expert on this but the warranty should cover failure of components like this whilst allowing for fair wear and tear. A seat belt failing after 2 years and 6,000 miles is not wear and tear, it just shouldn't happen in that time frame, even if it was trapped in the door a few times.
I think Suzuki are acting badly here, if you don't get anywhere you could tell the garage you are going on social media to express exactly what you think of their warranty and then if you don't get anywhere legal action, but you will need an independant inspection and you might not be able to use the car for a while.
It is probably an easy change, the sort of thing you could do yourself if you could get the part. It might be the same as a Gen 3 or other model if a Gen 4 is not available, does anyone know?
I don't see how you can be so confident in your first sentence. There is no evidence at all to support this conclusion.
It would also be odd to only wear/damage the belt in a very small area with a deep cut. If there was a sharp edge as the belt moved over it backwards and forwards, it would impact a much larger portion of the leading edge of the belt.
Cutting the webbing of a belt is also quite hard, so unless this was done with a knife. It would have been progressive and easy to spot in the early stages. If something really is sharp enough to cause an almost catastrophic failure of the belt, it should be very easy to identify.
20 Nov 2020 15:10 #230238 by DrRobin
Replied by DrRobin on topic GEN 4 Seat Belt fraying
I was just guessing, I doubt the owner has cut it with a knife, anyway it is not a clean cut but frayed and has been happening over a period of time. Everytime I have seen straps frayed like this it is where they either go through a sharp angle or have been clamped at this point. I have a couple of boat straps that have gone like this, it is where they go over the keel and change angle abruptly, neither has had that much use, but they are more than two years old.
Just thinking a bit, if it is on the shoulder when is use, then when it is most likely going on to the inertia reel when put away and is probably near the top of the drum (fully retracted). It might well be catching on something on one edge of inertia reel, that would explain the damage.
20 Nov 2020 15:58 #230239 by Micheal
Thanks for debating these points, I'm just waiting for someone to suspect me of a cunning plot to do away with the missus! Damn I've been found out!
Whether Suzuki do stand by this as a warranty claim or not as we all agree it will need to be replaced, the part is on order from Germany so lockdown permitting after the long 10 day lead time I'll take it in and hopefully see what the garage find when they dismantle to refit.
I will of course update the site when I hear anything further.
20 Nov 2020 16:07 #230240 by Roger Fairclough
Ask if you can watch when they take it off. If they say no (likely), then insist on having the belt for scrutiny. Do this at the dealers so they can see for themselves as to likely cause and act accordingly.
Roger
22 Nov 2020 17:22 #230282 by Micheal
Humble Pie!
It's a mouse problem. First time had a chance to take a good look under the bonnet and the critturs have stripped a fair bit of wiring insulation, inside they've also had a go at an area behing the passenger front seat.
Can't see any obvious hole they're getting inside from though.
I reckon a new wiring loom is going to be needed as well as other 'consumables', this is going to be an expensive repair so will need to look at insurance claim.
The wiring insulation does look very thin compared to stuff I'm used to like on a landrover. I saw that Toyota were sued in USA over this issue when they switched from petroleum based plastic insulation to soy. Rodents turned out to view the soy based insulation as a free snack. I wonder if Suzuki use the same material.
Question is how to stop this happening again.....
Time to create page: 0.207 seconds
