Re:Re:4 wheel drive issues
  • Biessels
31 Oct 2020 15:08 #229589 by Biessels
4 wheel drive issues was created by Biessels
Dear all, this is a help request from the Netherlands,
2 years ago i bought a jimny knewing that the 4 wheel drive wasn’ t working. The car has had multiple predecessors
Today i tried to change the automatic hubs for the manual hubs. It didnt work.
It appears to be that when I move the front prop shaft by hand the front axle is rotating, but when I put pressure on the front axle, it stops rotating.
I have the idea that some of my predecessors didn’t use the system wisely.
Requested advise,
Possible diagnose of the failure
Tips and advice about diagnosing the failure.
31 Oct 2020 15:19 #229590 by Lambert
Replied by Lambert on topic 4 wheel drive issues
Welcome to the forum. So if the 4x4 is working correctly then with the front wheels in the air if you restrict the propshaft then turn one wheel the opposite side should rotate the opposite direction to the side you are moving. With the propshaft free and one wheel restricted then moving the free wheel will rotate the propshaft. With both wheels free rotation of the propshaft should move both wheels fairly smoothly. When checking this be sure to secure the vehicle on axle stands and work carefully.
31 Oct 2020 16:45 #229592 by Scimike
Replied by Scimike on topic 4 wheel drive issues
Just want to say hello and welcome.
Do exactly what Lambert said and report back with any results or if it does not work.
31 Oct 2020 21:07 #229598 by jackonlyjack
  • Biessels
02 Nov 2020 16:06 #229626 by Biessels
Replied by Biessels on topic 4 wheel drive issues
Dear Lambert,
Thanks for reply. Next weekend i do some checks like you advised. For now.
I put the wheels in the air, with the hubs off. In 2 wheel drive mode. When i turn the propshaft the spine / axle?. Is turning. When i put pressure on the axle, the propshaft is still turning, but the axles dont move.
It is on both sides.
02 Nov 2020 17:30 #229629 by Lambert
If you have the hubs off then yes the propshaft would turn the axle shafts as they in turn drive the hubs which depending on if they are locked or not will either spin free or drive the wheel.
