Re:Re:4 wheel drive issues
04 Nov 2020 20:34 #229692
by McVicar
Replied by McVicar on topic Re:4 wheel drive issues
I came across this thread whilst doing a search for 4wd problems. Could I just ask a question. My vacuum pipes have corroded so thinking of fitting AVM manual hubs. If I do when I turn the hubs to 4wd is it then in 4wd or do I still use the stick to change between 2 and 4wd. Also if I don't blank off the pipes does the 4wd light only flash when in 4wd or all the time. Thanks.
- Roger Fairclough
- Thank you received: 225
04 Nov 2020 22:17 #229693
by Roger Fairclough
Replied by Roger Fairclough on topic Re:4 wheel drive issues
The hubs are part of a system and to be complete ie 4 wheel drive is engaged, the hubs must be locked in. With the hubs locked in you would then need to select 4wd on the selector lever in the cab. I cannot help you as to whether AVM hubs will fit or the result of blanking off the vacuum pipes.
Roger
Roger
- Thank you received: 1983
05 Nov 2020 04:26 #229694
Replied by Lambert on topic Re:4 wheel drive issues
I blanked the vacuum pipes at the solenoids to relive the flashing light. I also bridged the ports on the knuckles to keep dirt and moisture out. I have the regular avm hubs and they are fine for general use. There is a heavy duty version but that's probably better on more modified trucks. Its entirely possible to run the avm locked all day and just switch between 2 and 4 in the cab, when there's snow on the ground I will leave mine locked until its gone then I have 4x4 on demand.
05 Nov 2020 07:18 - 05 Nov 2020 07:19 #229695
by McVicar
Replied by McVicar on topic Re:Re:4 wheel drive issues
Thanks for the replies guys. I think I can manage changing the hubs but have no idea about blanking the pipes. For example, I don't even know what a solenoid looks like.
Last edit: 05 Nov 2020 07:19 by McVicar.
- Roger Fairclough
05 Nov 2020 09:05 #229698
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Re:4 wheel drive issues
A solenoid is a coil of copper wire which, when an electric current is passed through it, moves a metal rod that is situated within the coil. Bit like a linear motor. You operate a switch - usually on the dash - the solenoid is actuated, the rod moves and operates a pneumatic switch and vacuum created in the brake booster sucks the air out of the pipes and hoses and operates the vacuum system in the hubs. Blanking the pipes means your close off the ends by what ever means is available.
Roger
Roger
05 Nov 2020 12:20 #229707
Replied by Lambert on topic Re:Re:4 wheel drive issues
The solenoids are under the air box towards the bulkhead wires in one side rubber pipes out the other. You can use proper plastic bungs to seal them but i happened to find some nails in a suitable size, joys of being a farmer. Eventually when I get that far I will remove all the unwanted hardware and perform a wire bypass to keep the system from flashing as it will add a bit more lightness but I have been saying that for the last 6 years.
Time to create page: 0.210 seconds
