stop 4x4 light flashing
14 Oct 2020 16:25 #229129
by mcgowan
stop 4x4 light flashing was created by mcgowan
my vacuum pipes have rotted away and broken off one side at the wheel i have went with manual hubs so now how can i stop the 4wd light flashing cant do it at the wheel any place under the bonnet where would be best thanks
14 Oct 2020 16:32 #229130
Replied by mlines on topic stop 4x4 light flashing
Put a wire loop on the vacuum sensor switch located just under the front of the battery
14 Oct 2020 16:33 #229131
by sniper
Replied by sniper on topic stop 4x4 light flashing
On the inner wing below the battery, is the vacuum sensor, it has all the vacuum pipes going to it. Take the white two pin plug from it and bridge the two female spades with a wire bridge. That sends the vacuum present signal and stops the lights flashing.
Also remember....
Block the vacuum hoses at each calliper or water will be able to get in to the hub and goose your bearings.....
Block the vacuum line at the manifold or you will have a leak causing the engine to run poorly....
sniper
Also remember....
sniper
15 Oct 2020 10:07 #229139
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Replied by me101 on topic stop 4x4 light flashing
Have a look here, there are a couple of pics to show where the bits are:
www.clsdoncaster.com/post/jimny-4wd-issue-resolved
Cheers
Cheers
The following user(s) said Thank You: lookonimages
Time to create page: 0.169 seconds
