Raising the drivers seat.
30 Aug 2020 21:27 #227574
by Gadget
Replied by Gadget on topic Raising the drivers seat.
I raised the front edge of my seat (to provide more support under my thighs, as I've got quite long legs) by sticking a stack of washers on both bolts under each rail. Still plenty of meat left on the bolt to go into the captive nut. If you wanted to lift it by a lot, then look to buy some longer high-tensile steel bolts to be safe.
- Thank you received: 81
30 Aug 2020 21:49 #227575
by lightning
Replied by lightning on topic Raising the drivers seat.
Thank you for the replies. A 30mm lift on the Land Rover was sufficient so l would imagine 20mm will be fine in the Jimny.
l may initially try 10mm at the rear and nothing at the front.
- Thank you received: 1983
31 Aug 2020 06:51 #227579
Replied by Lambert on topic Raising the drivers seat.
Just using longer bolts with isolated spacers is putting too much faith in the moment resistance of the bolts. A much safer solution is a subframe of the appropriate height linking the bolt positions front to back and side to side.
- Roger Fairclough
- Thank you received: 225
31 Aug 2020 13:43 #227588
by Roger Fairclough
Replied by Roger Fairclough on topic Raising the drivers seat.
Lambert, he is not building the Eiffel Tower, he is raising the front of his seat by 10mm, in old money thats less than 1/2", and using an aluminium spacer of 20-25mm dia. with a mushroom headed bolt to spread the load on the seat runner will be more than adequate for the job.
Roger
Roger
31 Aug 2020 14:26 #227590
No not the Blackpool Tower but still a safety critical system of the car that we all sit on and trust to protect us, not something that should be bodged and certainly something that will attract the attention of an insurance loss adjustor. My insurance were adamant in requesting that my recaros be inspected by an independent recognised engineer. They are correctly installed and bolt to the factory location and the insurance were still twitching. It's why we have type approval etc.
- Roger Fairclough
31 Aug 2020 16:01 #227593
by Roger Fairclough
I fitted Recaro seats in my Land-Cruiser and the insurance company were happy to accept my statement that they were correctly fitted. Maybe my unblemished record with them had something to do with it.
Anyway, thats all water under the bridge and I have things to do. You take a discussion and convert into an argument and that doesn't interest me, so once again I will bow out and leave you to ponder the difference between small and tall and Eiffel and Blackpool.
Roger
Roger
Time to create page: 0.408 seconds
