Raising the drivers seat.
13 Nov 2020 13:45 #229979 by Roger Fairclough
I agree with CC on this. Any form of plastic will have a degree of flex and link that to inbuilt lubrication and the result could be a degree of squirm that, over a period of time, could loosen the bolts. I used aluminium without any problems. Just remember is use similar mushroom headed bolts.
It's not necessary to remove the seat from the car. If you want to though, you will find that disconnecting the two electrical connections - seat belt warning and seat heaters - takes longer than removing 4 bolts!
Roger
  • Groenewald
14 Nov 2020 07:08 #229997 by Groenewald
Replied by Groenewald on topic Raising the drivers seat.
CC Baxter wrote: I'm a great fan of plastics for engineering use (easy to machine, cheap to buy) but I'm not sure of your choice of Oilon. You're choosing a material that's main selling point is inbuilt lubrication. Rather than slippery seat mounts wouldn't Delrin for example be a better choice? Only a thought and if you can source something else quicker, where's the harm? Chris
Good point. I have already decided on Delrin. I think I still have a thick enough rod lying around.
The spacers are more visible from the outside than I thought and the green oilon will look downright weird...
22 Nov 2020 21:56 #230307 by lightning
Replied by lightning on topic Raising the drivers seat.
Thanks for all the replies.
l will try some aluminium spacers. One thing, when you loosen the rear seat bolt, the captive nut inside also seems to become loose.
Can l just confirm that the nuts don't disappear inside the floor when you remove the bolts?
03 Jan 2023 16:46 #246649 by aisle2
Replied by aisle2 on topic Raising the drivers seat.
We’re you able to figure this out? Any info you could share would be helpful
03 Jan 2023 17:35 #246650 by DrRobin
Replied by DrRobin on topic Raising the drivers seat.
I recently changed the seats in my Jimny, the original seats including rails are held in with four bolts, none of the nuts in the floor, moved, I assume they are welded in like the rear seat & seat belt fixings. One thing to note is the load area around the fixing bolts is fairly small and at least one bolt is at a different height from the others (the floor is uneven).
Anyway if you want to raise the seat a little, I don’t see why you couldn’t just buy longer bolts and use some spacers, I think the bolts are M10 (possibly M8), and there is plenty of room for a spacer, say 20 or 30mm square or round drilled for the bolts and length cut to suit.
If you were only going up 10-15mm, no one would notice, especially if you do both sides and with a decent spacer the strength and rigidity would be unchanged.
You can buy seat relocation brackets, these allow the seat to be moved further back, they are around 5mm thick, so you could mount them with a spacer and that would give a very solid platform for the raised seat.
Alternatively buy some of these tailored seat covers, they will raise you up a bit.
Robin
Time to create page: 0.160 seconds
