Raising the drivers seat.
- Thank you received: 81
30 Aug 2020 17:57 - 30 Aug 2020 17:59 #227564
by lightning
Raising the drivers seat. was created by lightning
l would like to raise the drivers seat a little, as l am quite small.
On the Defender you can buy a seat riser kit which raises the seat around 3cm at the back and 2cm at the front. This makes more difference than you might think.
l assume this isn't available for the Jimny. l wonder if it would be acceptable to fit spacers under the seat rails to raise the seat (say) 2cm at the rear and 1cm at the front.
Last edit: 30 Aug 2020 17:59 by lightning.
- Roger Fairclough
- Thank you received: 225
30 Aug 2020 18:39 #227566
by Roger Fairclough
Replied by Roger Fairclough on topic Raising the drivers seat.
I have raised the seat on my gen.4 by 20 mm at the front with no problems. I suggest aluminium for the spacers with a min.width of 20-25 mm and bolts to suit. You need to duplicate the type of bolt as mine were mushroom headed to spread the load.
Roger
Roger
- Thank you received: 1983
30 Aug 2020 19:10 #227569
Replied by Lambert on topic Raising the drivers seat.
If you're tall wouldn't moving the seat further back make more sense than lifting it and reducing the head room. Dave x8ggy of this parish does or did rails than move the seats back but only up a little.
30 Aug 2020 19:22 #227570
by lightning
Replied by lightning on topic Raising the drivers seat.
Hi there
l am small, not tall !
30 Aug 2020 19:30 #227571
Then I would suggest something in a steel box section and a note to the insurance. Seat mounts are an integral component of the impact mitigation system.
- Roger Fairclough
30 Aug 2020 21:02 #227573
by Roger Fairclough
The seat will still be mounted to the floor so the integrity of the impact mitigation system ie. seat belt will still be viable.
Roger
Roger
Time to create page: 0.198 seconds
