jimny breaking down
24 Aug 2020 09:56 #227265 by mcgowan
jimny breaking down was created by mcgowan
i have a 2002 jimny just don oil plugs etc while driving on motorway round 50 after about 10 miles she stopped after a few minutes it started up again spluttering then drive ok for another 9 or 10 mile and stopped again waited a while then stared again i think it must be a block in the fuel lines but where if i fit a inline filler would that help it
24 Aug 2020 10:16 #227268 by sniper
Replied by sniper on topic jimny breaking down
The cam sensor and crank sensor fail in a similar manner..... Did you get the eml light come on ? Get a fault code reader and have a look see...
sniper
24 Aug 2020 10:20 #227269 by Scimike
Replied by Scimike on topic jimny breaking down
What Sniper said ^^^^^
you can try to cool the sensor with water, if it works straight away you know its at fault.
The other item that can cause this type of issues is the coil packs and leads. If they are original it may be time to change them, especially as you disturbed them during the service and now you have the issue.
24 Aug 2020 11:55 #227278 by Busta
Replied by Busta on topic jimny breaking down
Normally the crank position sensor. If it is it won't have left any fault codes because when the signal stops the ecu just assumes the engine has stalled.
Time to create page: 0.086 seconds
