Re:Carrying additional fuel
18 Aug 2020 20:08 #226933 by Lambert
Replied by Lambert on topic Carrying additional fuel
that's not far off vaporising diesel. You can keep that. A nice pleasant 21c that more like it. 50 degrees Celsius! :laugh:
18 Aug 2020 20:20 #226935 by saxj
Replied by saxj on topic Carrying additional fuel
Lambert wrote: that's not far off vaporising diesel. You can keep that. A nice pleasant 21c that more like it. 50 degrees Celsius! :laugh:
After having been away from the car for an hour or so when it has stood in the sun, the steering wheel is too hot to touch, and if you are wearing shorts, the seat burns your arse.
18 Aug 2020 21:37 #226940 by Roger Fairclough
Another point to remember is what happens when you need the fuel and remove the cap.Whether it's just been bounced around or subject to 50c, the petrol will explode in your face.
Roger
18 Aug 2020 22:27 #226944 by Busta
Replied by Busta on topic Carrying additional fuel
Depends where you put your face in relation to the cap. And explode is a bit of an exaggeration. I'd hope most people know how to open a pressurised container safely.
19 Aug 2020 05:12 #226949 by Lambert
Roger Fairclough wrote: Another point to remember is what happens when you need the fuel and remove the cap.Whether it's just been bounced around or subject to 50c, the petrol will explode in your face.
Roger
Not really a problem if you only put the stated amount of fuel into the can. The stated capacity has an allowance for fuel expansion. If you over fill it to the brim you will have a problem but why would you do that with a volatile liquid?
19 Aug 2020 05:30 - 19 Aug 2020 06:37 #226952 by lookonimages
saxj wrote: Here in South Africa, none of us would ever consider carrying fuel on the inside of the car. Maybe because our temperatures are higher. But one of the thing to consider is, if you are in an accident and your fuel container ruptures, what are the consequences?
Not really. I carry fuel inside car 2x jerry cans. Heat is never an issue. Namibia an botswana in 40 degrees. Jerry canns also seal properly. There is no fumes etc.
Frontrunner jerrycan holder keep them nice and tight. I have the double jerrycan set.
Cans outside car in direct sunlight gets hotter anyway.
Last edit: 19 Aug 2020 06:37 by lookonimages.
