fuel consumption
08 Aug 2020 08:44 #226315
by mcgowan
fuel consumption was created by mcgowan
my 2002 jimny has got very sore on fuel about 20 to the gallon normal driving any thing i can check are replace
08 Aug 2020 08:48 - 08 Aug 2020 08:49 #226316
by Scimike
Replied by Scimike on topic fuel consumption
Hi,
Is it standard or modified?
In any case I would start with a full service, oils, plugs and filters. Also check the brakes are free on each wheel.
My standard 2009 over my ownership average is 36.2 mpg,
Mike
Mike
Last edit: 08 Aug 2020 08:49 by Scimike.
08 Aug 2020 08:58 #226317
by mcgowan
Replied by mcgowan on topic fuel consumption
it standard i will do that thanks
- jfkenpoman
31 Aug 2020 18:10 #227600
by jfkenpoman
Replied by jfkenpoman on topic fuel consumption
mine is getting about that but i have a 2" suspension lift and 5 x steel rims with 215 BRG A/T fitted
- Thank you received: 2004
31 Aug 2020 18:21 #227601
Replied by Lambert on topic fuel consumption
I can get fuel consumption that high but I have to be at full train weight to achieve it. Normally my consumption is in the middle 30s. As well as the above suggestions check your tyre pressure isn't monstrously low.
31 Aug 2020 19:25 - 31 Aug 2020 19:26 #227602
Replied by mlines on topic Re:fuel consumption
My fully modified, seriously overweight Jimny with 32 inch tyres, cage, winch, front and rear steel bumpers and SJ transfer box with 6:1 gears does around 18 mpg
Last edit: 31 Aug 2020 19:26 by mlines.
