Re:What tyre psi you running???
- Phattaff
31 Jul 2020 11:07 #225893
by Phattaff
Replied by Phattaff on topic What tyre psi you running???
Ok just checked my pressures OMG 30psi, now down to 20 phew.
- Grima
31 Jul 2020 19:02 #225901
by Grima
Replied by Grima on topic What tyre psi you running???
MMMM, I'm sure i read a similar thread that BFG KO2 215 75 15 tyres should be 28 to 30psi. That was from the tyre company. I found tyre side wall sway with lower pressure when doing tight turns on road, giving a rear end slide feeling. 28/30 gives a firmer feel on roundabouts & turns also reduced road noise.
31 Jul 2020 19:18 #225902
by Busta
Replied by Busta on topic What tyre psi you running???
Given the extra volume of the tyres, those are very high pressures! The load rating on my 215/75 KM2s is 800kg at 50psi! The Jimny is about 300kg/corner, so keeping it proportional for maths' sake that comes to 18.75psi.
Can't say I've ever noticed an undue amount of sidewall flex with them at 21psi and on the limit they transition into a slide nice and progressively. They get a bit wobbly below 15psi though.
- Thank you received: 1994
31 Jul 2020 19:41 #225904
That's going to be fine for a much heavier vehicle than a Jimny. I think from memory that one of the transporter syncro vans used a similar size which would be right for 30 psi.
Replied by Lambert on topic What tyre psi you running???
Grima wrote: MMMM, I'm sure i read a similar thread that BFG KO2 215 75 15 tyres should be 28 to 30psi. That was from the tyre company. I found tyre side wall sway with lower pressure when doing tight turns on road, giving a rear end slide feeling. 28/30 gives a firmer feel on roundabouts & turns also reduced road noise.
- Grima
31 Jul 2020 19:46 #225905
by Grima
Am I right in saying standard wheel width is 15.5, if so then writing on the tyre states "Danger do not fit on a 15.5 rim" That's why more pressure is needed to compensate for the cheese wedge effect.
31 Jul 2020 19:53 #225906
by Busta
They say "Danger. Do not use on 15.5" DIAMETER rims".
The Jimny uses 15" rims. This has nothing to do with tyre pressures.
Time to create page: 0.197 seconds
