Re:What tyre psi you running???
- Phattaff
28 Jul 2020 08:52 #225775
by Phattaff
What tyre psi you running??? was created by Phattaff
Running 235/75/15s not sure what pressure they should be.
28 Jul 2020 09:31 #225776
Replied by mlines on topic What tyre psi you running???
20 psi for me
28 Jul 2020 11:16 #225777
by 300bhpton
Replied by 300bhpton on topic What tyre psi you running???
On road, off road, towing, hauling, type of tyre, type of driving?
- Thank you received: 1997
28 Jul 2020 12:51 #225781
Replied by Lambert on topic What tyre psi you running???
The tyre will have a maximum load at a maximum pressure written on the sidewalls. Either using the maximum axle weights off the vin or actually measuring the weight on each axle you can use maths to work out the pressure from the maximum figures on the tyre.
28 Jul 2020 14:10 #225787
Replied by jackonlyjack on topic What tyre psi you running???
22 psi all four 195/80/16 extreme retreads
Same in bfg km2 225/75/16
28 Jul 2020 18:54 #225797
by Busta
Replied by Busta on topic What tyre psi you running???
I run 21psi in 215/75r15s. 19-20psi would seem about right for 235s.
Time to create page: 0.195 seconds
