Towing socket 3
  • Orvil
06 Jul 2020 07:49 #224572 by Orvil
Replied by Orvil on topic Towing socket 3
Hi again got my new vehicle socket and bracket .. Took the old bracket off fell to bits just about 3 bolts holding socket on it over rusted on inspection 1 wire ad broke own near connection grub screw. Checking rest for power no responses looking for connections behind left side panel couple of wires with scotch blocks. Rest under wheel arch back of bottom left light a ball of red tape took some get off more scotch blocks what a job had to check every scotch block and refix and clean took some hours finding touch and go connections sorted out in the end but going to better them connections with solder and shrink wrap or something. Just wondering could I smear the back of socket with Vaseline or grease. Them scotch blocks might be a quick fix but bring on trouble years on I say.
06 Jul 2020 07:59 #224573 by Lambert
Replied by Lambert on topic Towing socket 3
The last time I was in the trailer wiring on Dreadnaught I was liberal with the waterproof grease. Can't see why people don't do it as a matter o course.
  • Orvil
06 Jul 2020 09:59 #224574 by Orvil
Hi Lambert
That's what I thought when I had fishing boats use to cover what I could with desk tape round starter mother and alternated on in board engines. I done all the bolts and bracket with coating copper slip grease just thought might be conductivity near wiring connections but cheers all with tips and help.
  • Orvil
06 Jul 2020 10:02 #224575 by Orvil
Denso tape. This American keyboard makes its own language.
06 Jul 2020 10:09 #224576 by RainerK
Replied by RainerK on topic Towing socket 3
Before I would play around with scotch blocks or soldering I would get a connection set. The are not so expensive and will save a lot of problems.
And using some kind of corrosion protection is a good idea, especially for the socket outside the car. I usually use Fluid Film Max Spray or Mike Sanders Fat.
06 Jul 2020 15:44 #224598 by Scimike
Replied by Scimike on topic Towing socket 3
I tend to spray the back of my towing sockets with Waxoyl or Dinatrol, only because its easier to apply and gets into all nooks and crannies, but grease is fine if you don't have a can.
Time to create page: 0.111 seconds
